pb66
(Paul)
5
Unfortunately you cannot.
At this time emonHub doesn’t fully support named nodes and only a node id (integer) is used in most places. Unlike the input names there is no “friendly node name” option in emoncms, if you could change the “Node 5” to something else at the emoncms.org end, it would no longer be found as “Node 5” and it would stop updating and a new “Node 5” created automatically when the next data arrived.
