Hello,
I am not trying to go against physical limitation of RF (limited to 30 nodes by EmonBase), but i have 3 emonBase with 24 EmonTH connected to each one.
The thing is I have different network group , different base ID (emonBase/emonPi as emonhub.conf says), and what I want to achieve is this kind of logic:
EmonBase01 from node 1 to 24 / group 201 / baseid 1 (# emonPi / emonBase nodeID)
EmonBase02 from node 25 to 48 / group 202 / baseid 2 (# emonPi / emonBase nodeID)
EmonBase03 from node 49 to 72 / group 203 / baseid 3 (# emonPi / emonBase nodeID)
Each EmonBase post data to the same custom EmonCms server
How can I do that? because this node ID seems to be just a string
I try to go through the limitation by debugging what behind interfacers but this is a lot a reading and I think you got the answer
Otherwise, seems that logic emonpi node ID (emonBase/emonPi) coupled with network does not work with this architecture:
EmonBase02 from node 1 to 24 / group 202 / baseid 2 (# emonPi / emonBase nodeID)
EmonBase03 from node 1 to 24 / group 203 / baseid 3 (# emonPi / emonBase nodeID)
Same nodes name from different EmonBaseXX are overwritten themselves in this case
Thanks in advance
