Hello,
I setup a fresh hostet Linux Server and install Emoncms 9 Master git:
cat /etc/*-release
DISTRIB_ID=Ubuntu DISTRIB_RELEASE=14.04 DISTRIB_CODENAME=trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.4 LTS" NAME="Ubuntu" VERSION="14.04.4 LTS, Trusty Tahr" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 14.04.4 LTS" VERSION_ID="14.04" HOME_URL="http://www.ubuntu.com/" SUPPORT_URL="http://help.ubuntu.com/" BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/" 12.5.30 ubuntu14.04.build1205150826.19
All is running, but get not Redis to work.
Redis is installed:
ps aux | grep redis
redis 17527 0.0 0.0 41040 1772 ? Ssl 09:46 0:00 /usr/bin/redis-server 127.0.0.1:6379
But I get the error on the website:
settings.php file error
redis enabled but not installed, check setting: redis_enabled
To fix, check that the settings are set in settings.php or try re-creating your settings.php file from default.settings.php template
My settings.php.
//2 #### Redis $redis_enabled = true; $redis_server = array( 'host' => 'localhost', 'port' => 6379, 'auth' => '', 'prefix' => 'emoncms');
Where is the problem?
Thank you!
