Hi again,
I tried connecting my Sontex 789 to the emonHP today (still waiting for installation of electrical meters). The emonHP is successfully communicating with emoncms.org, but the info from the Sontex 789 mbus don’t seem to be coming through correctly, see below from the emonHP log. Any ideas @TrystanLea? Thanks very much!
2022-11-15 20:17:30,748 DEBUG MBUS Invalid MBUS data received 146 bytes 718.4 ms
2022-11-15 20:17:30,750 DEBUG MBUS Decoded MBUS data: {"Energy": [776, "kWh"], "Energy2": [349, "kWh"], "Energy3": [117, "kWh"], "Energy4": [0, "kWh"], "Energy5": [0, "kWh"], "Energy6": [0, "kWh"], "Energy7": [0, "kWh"], "Energy8": [0, "kWh"], "Energy9": [0, "kWh"], "Energy10": [0, "kWh"], "Energy11": [0, "kWh"], "Energy12": [0, "kWh"], "Energy13": [0, "kWh"], "Energy14": [0, "kWh"], "Energy15": [0, "kWh"], "Energy16": [0, "kWh"], "Energy17": [0, "kWh"], "Energy18": [0, "kWh"]}
2022-11-15 20:17:30,750 DEBUG MBUS 7171 NEW FRAME :
2022-11-15 20:17:30,751 DEBUG MBUS 7171 Timestamp : 1668543450.029469
2022-11-15 20:17:30,751 DEBUG MBUS 7171 From Node : heatmeter
2022-11-15 20:17:30,751 DEBUG MBUS 7171 Values : [776, 349, 117, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2022-11-15 20:17:30,752 DEBUG MBUS 7171 Sent to channel(start)' : ToEmonCMS
2022-11-15 20:17:30,752 DEBUG MBUS 7171 Sent to channel(end)' : ToEmonCMS
2022-11-15 20:17:30,988 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy 776
2022-11-15 20:17:30,989 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy2 349
2022-11-15 20:17:30,990 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy3 117
2022-11-15 20:17:30,990 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy4 0
2022-11-15 20:17:30,991 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy5 0
2022-11-15 20:17:30,992 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy6 0
2022-11-15 20:17:30,993 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy7 0
2022-11-15 20:17:30,994 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy8 0
2022-11-15 20:17:30,994 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy9 0
2022-11-15 20:17:30,995 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy10 0
2022-11-15 20:17:30,996 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy11 0
2022-11-15 20:17:30,997 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy12 0
2022-11-15 20:17:30,998 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy13 0
2022-11-15 20:17:30,999 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy14 0
2022-11-15 20:17:30,999 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy15 0
2022-11-15 20:17:31,000 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy16 0
2022-11-15 20:17:31,001 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy17 0
2022-11-15 20:17:31,002 DEBUG MQTT Publishing: emon/heatmeter/heatmeter_Energy18 0
2022-11-15 20:17:31,003 INFO MQTT Publishing 'node' formatted msg
2022-11-15 20:17:31,003 DEBUG MQTT Publishing: emonhub/rx/heatmeter/values 776,349,117,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Edit - formatted text. Moderator
