I’m trying to send some commands to the OpenEVSE via RAPI (happens in all methods, MQTT, HTTP and GUI RAPI). When I send the command $FS (to pause the charging), the system goes into sleep and returns to changing immediately after. If I press sleep in the web gui button or in the physic button, the system goes into sleep. I send the MQTT topic openevse/rapi/in/$FS or the http:/r?rapi=%24FS
The same happens if I try to remove the device from the sleep state
Ok, I fund the problem, if I set a timer, I’m not able to override with the RAPI. I would like to keep the timer, but send commands to override it when I need to! Not Possible?
So from what I can see, if I have a timer set, that I need to have to ensure that the car only charges in the cheapest time, and if for some reason I need to bypass and override the charging instruction, over rapi (i use a integration), I need to cancel the trimmer first, and then change the car. After that I need to reset the charger timer and turn it on again!
No way to force the charge if the system is sleeping, like with the physic button?!
