MQTT has a publish and subscribe mechanism.
Publish is one device sending data to the MQTT Broker
Sebscribe is one device asking the MQTT Broker for data.
Emoncms looks for any topic with the base topic emon/ and then pulls that data in as an Input.
If you want to publish data from Emoncms for other devices to use, you need to use a different base topic name else it will appear as an INput
How is Grid created in the first place. I think you have created a loop and it keeps appearing as the retain flag is set.
