Hi All,
I have an L3 monitored HP installation, but despite setting Publicly shared to yes, it doesn’t seem to be open to being found on HPM.org, it also shows as “not Published” though I’m not 100% clear on what that means.
Is there something else I need to enable/select?
Hello @Technobod published this for you now
Thanks Tristan, but for others benefit finding this thread, is this something that happens on a fixed schedule or after a certain amount of data or is it by request?
We manually review all systems before they go live on HPM. We try to do this within 24hrs, but it could take 1-2 days if we’re busy! To approve a system, we need to see data of the heat pump running and the HPM form to be sufficiently filled in with system context.
