Community
OpenEnergyMonitor
Community
Problems with GPIO push button on self build emonPi
(tonertiffi) #58
    for sensor in Sensors:
        temp = read_temp(sensor['id'])
        if temp >= sensor['on']:
                gpio.output(sensor['pin'], gpio.LOW)
                sensor['status'] = 1
        elif temp <= sensor['off']:
                gpio.output(sensor['pin'], gpio.HIGH)
                sensor['status'] = 0
            publish_data('emon/Fans/' + sensor['name'] + '/values', sensor['status'])
            #publish_data('emon/' + sensor['name'] + '/Status/values', sensor['status'])
            publish_data('emon/Temperatures/' + sensor['name'] + '/values', temp)
            #publish_data('emon/' + sensor['name'] + 'Temperature/values', temp)
                publish_data('emon/Fans/' + sensor['name'] + '/values', 1)
                #publish_data('emon/' + sensor['name'] + '/Status/values', 1)
                publish_data('emon/Fans/' + sensor['name'] + '/values', 0)
                #publish_data('emon/' + sensor['name'] + '/Status/values', 0)
    time.sleep(6)
(Paul) #59
Well yes there are some indentation errors there, for some reason you have duplicated some code one level in
#!/usr/bin/python3
import glob
import time
import paho.mqtt.publish as publish
import RPi.GPIO as gpio
Broker = '127.0.0.1'
auth = {
    'username': 'emonpi',
    'password': 'emonpimqtt2016',
Sensors = {{'name':'SENSOR_A','id':'28-800000abc123','pin':1,'on':20,'off':15},
           {'name':'SENSOR_B','id':'28-800000def456','pin':2,'on':20,'off':15},
           {'name':'SENSOR_C','id':'28-800000abc456','pin':3,'on':20,'off':15}}
def read_temp(sensorid):
    valid = False
    temp = 0
    device_file = '/sys/bus/w1/devices/' + sensorid + '/w1_slave'
    with open(device_file, 'r') as f:
        for line in f:
            if line.strip()[-3:] == 'YES':
                valid = True
            temp_pos = line.find(' t=')
            if temp_pos != -1:
                temp = float(line[temp_pos + 3:]) / 1000.0
    if valid:
        return temp
    else:
        return None
def publish_data(topic, value):
    publish.single(topic, str(value),
                    hostname=Broker, port=1883,
                    auth=auth,)
    return
gpio.setmode(gpio.BOARD)
    gpio.setup(sensor['pin'], gpio.OUT)
while True:
        if temp is not None:
    time.sleep(6)
(tonertiffi) #60
Convinced you a genius :smiley:
(tonertiffi) #61
In my effort i managed to break this, it does not update the values, if i hit refresh it works , go out, go back in values updated,never turns red
(tonertiffi) #62
Check pc time bottom left:smiley:
(Paul) #63
Sorry I don’t follow, are you saying emoncms is no longer refreshing?
Try using ctrl-f5 to see if that fixes it OR has your log in session timed out?
(tonertiffi) #64
Correct
it works everywhere else except for the feeds page.
(Paul) #65
I’m still not sure what you mean, you are showing us the graph page which is data derived from the feeds, it cannot update unless the feeds update. Which is why I suggested a clear cache to the browser.
(Paul) #66
What is that “paused” button?
(tonertiffi) #67
Gmail is paused :slight_smile:
(Paul) #68
ahh ok! :slight_smile:
(tonertiffi) #69
Ok this is what i do, and the results.
I go to the inputs and select a feed add it (log to feed)
I go to the feed page its not updating.
I delete that feed i just created (log to feed), the rest start updating.
i go out of the feed page, i go back in no feeds updating
(tonertiffi) #70
I changed on the My account,My profile, Beta Features:
Device Module Beta
was On, to OFF
started working 100%
(tonertiffi) #71
Its now 24:30pm here, will run it till the morning and let you know, If its still updating ok.
(Paul) #72
Please do. If the issue persists it sounds like something @TrystanLea should be aware of.
Just as another test, can you try using input and feed names without any special characters, it should be able to handle a couple of underscores, but you never know.
(tonertiffi) #73
Hi @pb66 ran it through the night, till now no problem, feeds r there, everything working 100%.As long as i do not switch to
(tonertiffi) #74
Hi @pb66, wondered on something, some off the gpio pins,on the RPI seem to have a low voltage not activated. I noticed that when i plug in the relay, eg IN1 signal to a random gpio pin on the RPI, the led on the pba has a very small glow, without doing anything.(this relay pba has 2x status leds) can i assume the following, that the pin gets the correct state, when being told what to do so from the script (else a small voltage on the pin if unused.)
, any idea? Not using it that way now RPI supplies the ground and power .
but that is my plan to use it as the final build.dJ5wKNh
(tonertiffi) #75
The end goal, so far all this is working 100%, thanks to allot of help from @pb66
(tonertiffi) #76
Hi @pb66 sorry for asking you again, I have acquired a 20x4 lcd I2c, it updates a hole lot quicker than the 16x2 for some strange reason. Sorry my question would i be able to use the extra 2 lines to display values.
I assume you have to alter, home/emonpi/lcd/emonPiLCD.py
# MQTT Settings
mqtt_user = config.get('mqtt','mqtt_user')
mqtt_passwd = config.get('mqtt','mqtt_passwd')
mqtt_host = config.get('mqtt','mqtt_host')
mqtt_port = config.getint('mqtt','mqtt_port')
mqtt_emonpi_topic = config.get('mqtt','mqtt_emonpi_topic')
mqtt_feed1_topic = config.get('mqtt','mqtt_feed1_topic')
mqtt_feed2_topic = config.get('mqtt','mqtt_feed2_topic')
# Redis Settings
redis_host = config.get('redis', 'redis_host')
redis_port = config.get('redis', 'redis_port')
r = redis.Redis(host=redis_host, port=redis_port, db=0)
# General Settings
# LCD backlight timeout in seconds 0: always on, 300: off after 5 min
backlight_timeout = config.getint('general','backlight_timeout')
default_page = config.getint('general','default_page')
#Names to be displayed on power reading page
feed1_name = config.get('general','feed1_name')
feed2_name = config.get('general','feed2_name')
feed1_unit = config.get('general','feed1_unit')
feed2_unit = config.get('general','feed2_unit')
(tonertiffi) #77
Please tell me its as simple as adding in 2 more feeds :slight_smile:
