Community
OpenEnergyMonitor
Community
Problems with GPIO push button on self build emonPi
(Paul) #52
My bad, in my head I had changed the Sensors format to a list of dicts but failed to make that edit. Change the 2 outer curly braces to square bracket like so
Sensors = [{'name':'SENSOR_A','id':'28-800000abc123','pin':1,'on':20,'off':15},
           {'name':'SENSOR_B','id':'28-800000def456','pin':2,'on':20,'off':15},
           {'name':'SENSOR_C','id':'28-800000abc456','pin':3,'on':20,'off':15}]
I will try and keep an eye on the forum in case you have further issues, but I have quite a bit on this weekend so I do not know if or when I might be about yet.
(tonertiffi) #53
You are truly brilliant @pb66 .:smiley: Attached screen shots, from 1st to last, the relay does activate and deactivate. Never had to change anything in the code except for the [ ].
Just that i understand readings go red, take it, it cannot read the state of the pin?
When state turns back to 0 it carries on reading it no problem.
Thank you very much.
(Paul) #54
That makes sense, I had just added the publish line to the change of pin status code so it only publishes when the state changes, that is how I would expect a “status” to work on MQTT, but you are right, emoncms expects a constantly updating value I guess, for graphs etc to view better.
it’s an easy fix, change the existing control code like so
            if temp >= sensor['on']:
                gpio.output(sensor['pin'], gpio.LOW)
                sensor['status'] = 1
            elif temp <= sensor['off']:
                gpio.output(sensor['pin'], gpio.HIGH)
                sensor['status'] = 0
        publish_data('emon/Fans/' + sensor['name'] + '/values', sensor['status'])
        #publish_data('emon/' + sensor['name'] + '/Status/values', sensor['status'])
The status variables also needs defining before entering the main loop, just in case a temp reading is None and it tries to publish a status before it gets a valid read. Add sensor['status'] = 0 to the gpio setup code immediately before entering the main loop, eg
for sensor in Sensors:
    gpio.setup(sensor['pin'], gpio.OUT)
while True:
(tonertiffi) #55
Hi Paul,
Get the following error
[email protected]:/usr/local/bin $ python mqtt-temp
File “mqtt-temp”, line 50
if temp >= sensor[‘on’]:
IndentationError: unexpected indent
(Paul) #56
That’s most likely a copy and paste error. Python is very fussy about indentation, looking at the script there are 4 levels of indentation (plus no indentation). the if temp >= sensor['on']: line is on the 3rd level of indentation which means it probably must have 3 tabs or 12 spaces depending on what style you are using.
Beware of stray white space and or line endings altering things from what you see to what is seen by Python.
If you cannot resolve the problem you need to post the code you have leading up to and after the point it says is at fault as the required indention is defined by the code around it.
(tonertiffi) #57
Hi @pb66
  File "mqtt-temp", line 55
IndentationError: unindent does not match any outer indentation level
(tonertiffi) #58
        temp = read_temp(sensor['id'])
            publish_data('emon/Temperatures/' + sensor['name'] + '/values', temp)
            #publish_data('emon/' + sensor['name'] + 'Temperature/values', temp)
                publish_data('emon/Fans/' + sensor['name'] + '/values', 1)
                #publish_data('emon/' + sensor['name'] + '/Status/values', 1)
                publish_data('emon/Fans/' + sensor['name'] + '/values', 0)
                #publish_data('emon/' + sensor['name'] + '/Status/values', 0)
    time.sleep(6)
(Paul) #59
Well yes there are some indentation errors there, for some reason you have duplicated some code one level in
#!/usr/bin/python3
import glob
import time
import paho.mqtt.publish as publish
import RPi.GPIO as gpio
Broker = '127.0.0.1'
auth = {
    'username': 'emonpi',
    'password': 'emonpimqtt2016',
Sensors = {{'name':'SENSOR_A','id':'28-800000abc123','pin':1,'on':20,'off':15},
           {'name':'SENSOR_C','id':'28-800000abc456','pin':3,'on':20,'off':15}}
def read_temp(sensorid):
    valid = False
    temp = 0
    device_file = '/sys/bus/w1/devices/' + sensorid + '/w1_slave'
    with open(device_file, 'r') as f:
        for line in f:
            if line.strip()[-3:] == 'YES':
                valid = True
            temp_pos = line.find(' t=')
            if temp_pos != -1:
                temp = float(line[temp_pos + 3:]) / 1000.0
    if valid:
        return temp
    else:
        return None
def publish_data(topic, value):
    publish.single(topic, str(value),
                    hostname=Broker, port=1883,
                    auth=auth,)
    return
gpio.setmode(gpio.BOARD)
while True:
        if temp is not None:
    time.sleep(6)
(tonertiffi) #60
Convinced you a genius :smiley:
(tonertiffi) #61
In my effort i managed to break this, it does not update the values, if i hit refresh it works , go out, go back in values updated,never turns red
(tonertiffi) #62
Check pc time bottom left:smiley:
(Paul) #63
Sorry I don’t follow, are you saying emoncms is no longer refreshing?
Try using ctrl-f5 to see if that fixes it OR has your log in session timed out?
(tonertiffi) #64
Correct
it works everywhere else except for the feeds page.
(Paul) #65
I’m still not sure what you mean, you are showing us the graph page which is data derived from the feeds, it cannot update unless the feeds update. Which is why I suggested a clear cache to the browser.
(Paul) #66
What is that “paused” button?
(tonertiffi) #67
Gmail is paused :slight_smile:
(Paul) #68
ahh ok! :slight_smile:
(tonertiffi) #69
Ok this is what i do, and the results.
I go to the inputs and select a feed add it (log to feed)
I go to the feed page its not updating.
I delete that feed i just created (log to feed), the rest start updating.
i go out of the feed page, i go back in no feeds updating
(tonertiffi) #70
I changed on the My account,My profile, Beta Features:
Device Module Beta
was On, to OFF
started working 100%
(tonertiffi) #71
Its now 24:30pm here, will run it till the morning and let you know, If its still updating ok.
