I am trying to log the Import Power as per the Guide. However it isn’t working correctly, either because I have the processes in the wrong order or I misunderstood the configuration.
I think that WhAccumulator is the spanner in the works, try removing that so that the raw power value is passed on to the minus solar.
I would also add a “nett grid” log to feed after the -solar, then if the import is correct all you then need is to add “reset to zero” then “+feed” “nett grid” “allow negative” “log to feed” “export_power” etc.
