championc
(Cormac Champion)
1
Hi all,
I don’t understand as to what I am missing here. Here is my feed
So the Heat and Electric values are correct in kW’s, but they are being interpreted as WATTS in my graph
System - Emoncms - app view
The gap in monitoring was because I turned the whole system off to upgrade some pipes and add another rad to the sitting room
Timbones
(Tim)
2
You need to set your Heat and Electric feeds to be recorded in watts.
Easy to do by adding x 1000
to the input process steps:
Remember to edit Unit for the feed too:
championc
(Cormac Champion)
5
Crossed posts. Many thanks
