I already changed the file settings.php :
'phpfiwa'=>array(
'datadir'=>"C:\wamp64\www\emoncms\Lib\emoncmsdata\phpfina"
'phpfina'=>array(
'datadir'=>"C:\wamp64\www\emoncms\Lib\emoncmsdata\phpfiwa"
'phptimeseries'=>array(
'datadir'=>"C:\wamp64\www\emoncms\Lib\emoncmsdata\phptimeseries"
'cassandra'=>array(
'keyspace' => 'emoncms'
and
$log_filename = dirname(__FILE__).'C:\wamp64\www\emoncms' . "emoncms.log"
and in the file process_settings.php:
if(file_exists(dirname(c:\wamp64\www\emoncms). "settings.php"))
but I get an error
Parse error: syntax error, unexpected ':' in C:\wamp64\www\emoncms\process_settings.php on line 19
and i not could get a registration in emoncms
blaal02
(SandyB)
7 March 2018 14:30
#2
Hi Joaquim,
Can you try doubling those backslashes, so:
C:\\wamp64\\www\\emoncms\\Lib…
(or have you already and it’s just the forum showing single).
However, your error mentions line 19 - in the standard setup, that’s the REDIS config.
Thanks,
Sandy
pb66
(Paul)
7 March 2018 16:40
#3
I agree with SandyB’s suggestion
'phpfiwa'=>array(
'datadir'=>"C:\\wamp64\www\emoncms\\Lib\\emoncmsdata\\phpfina"
'phpfina'=>array(
'datadir'=>"C:\\wamp64\\www\\emoncms\\Lib\\emoncmsdata\\phpfiwa"
'datadir'=>"C:\\wamp64\\www\\emoncms\\Lib\\emoncmsdata\\phptimeseries"
'cassandra'=>array(
(the forum doesn’t need the backslashes escaped when in a code block)
As for the logfile path, your edit will probably result in
C:\\path\\to\\emoncms\\C:\wamp64\www\emoncmsemoncms.log
try reverting that to
$log_filename = dirname(__FILE__) . "\\emoncms.log"
or something like
$log_filename = "C:\\wamp64\\www\\emoncms\\emoncms.log"
for an absolute path
I do not understand why you have edited process_settings.php, that is a relative path derived from the “FILE ” path and should work ok in windows.
