no I loged out and in again still no apps do I type that command at the above prompt
command prompt is still open at the above screenshot
still no apps
I only purchased the unit 3 weeks ago so it should have been up to date
borpin
(Brian Orpin)
24
Odd. What version is you system at?
On the update button, click on the pull down arrow and click on Update EmonCMS
project- id -version emoncms 8.4.0 admin
Should I reboot the pi
Did you mean me to press this update button
Try running “Full Update” to update to latest version of Emoncms V10
Done that and the apps are back now, but it now wont download again the screen graph is smaller than before is that correct
borpin
(Brian Orpin)
29
Yes that is how it is now.
You should now be able to run the commands above to pull master branch and see if your issue is fixed.
Assumptions! We assumed you were already up to date!
@glyn.hudson I’ll edit your post above to ensure anyone following on is fully upto date before trying the commands.
Thanks! Yes, sorry this was my assumption also
OK will run your commands again
no need if you have ran them before and are already on master branch
Yes, MySolarPV app has been optimised to better fit on mobile devices.
I’ve just tested CSV feed download again and it’s working fine for me. Please post a screenshot of the error you see:
I had run the update again before your last message and it is exporting fine now. thanks for the help.
borpin
(Brian Orpin)
34
I’d put him back on stable before I realised he was no up to date.
