Hi
I have a python script that scrapes data from my inverters and passes it to emoncms within NodeRED, for some reason I cant get it to work. The interface is the “output to emoncms” node that’s within NodeRED.
Can somebody check that I’ve got the string correct as I’m getting 2017-08-09 18:25:43.407|ERROR|input_controller.php|Format error: csv value is not numeric
in the logs
1 Serial: 404000128572, 1 Power: 2, 1 Freq: 50.0, 1 Temp: 15, 2 Serial: 404000128572, 2 Power: 1, 2 Freq: 50.0, 2 Temp: 15, 3 Serial: 404000128462, 3 Power: 2, 3 Freq: 50.0, 3 Temp: 14, 4 Serial: 404000128462, 4 Power: 2, 4 Freq: 50.0, 4 Temp: 14, 5 Serial: 404000128304, 5 Power: 2, 5 Freq: 50.0, 5 Temp: 14, 6 Serial: 404000128304, 6 Power: 1, 6 Freq: 50.0, 6 Temp: 14, 7 Serial: 404000128436, 7 Power: 2, 7 Freq: 50.0, 7 Temp: 15, 8 Serial: 404000128436, 8 Power: 2, 8 Freq: 50.0, 8 Temp: 15, 9 Serial: 404000128356, 9 Power: 1, 9 Freq: 50.0, 9 Temp: 15, 10 Serial: 404000128356, 10 Power: 1, 10 Freq: 50.0, 10 Temp: 15,
I believe the format should be??
Title: Value, Title2: Value2,
Regards
Dave
