Placement of heat pump outside temperature sensor
Hi all,
Last year I noticed a small drop (up to 0.5c) in the outside temperature reported by my Samsung Gen 6 when it started up.
I decided that this was due to the placement of the sensor, behind the unit in the air flow so I moved it slightly out of the air flow and then it continued to record the same temperature either side of starting.
I don’t think it really matters much but may prevent a defrost in borderline conditions.
I’d be interested to see what you all think.
Thanks in advance!
Christian.
It may actually indicate you are recycling air and not misreading unless exposed to the sun etc. Te air temperature is just that the air temperature the only way it drops is when you introduce cooler air, is the outlet air being bounced off something in front of the ASHP?
Yep, done the same thing, previously discussed here …
