You should be following the emonLibCM calibration, not that for emonLib (the Discrete Sample version) which is what that ‘Learn’ article describes. Unfortunately, I don’t have easy access to that documentation to be able to change it. If you download the emonLibCM zip file complete, you’ll find the full documentation in there. I can’t give you typical values, because (a) I don’t have a USA adapter and (b) I run on 50 Hz mains, and the phase errors of the transformers will be different.
