Panasonic Aquarea Controller Temperature callibration
Hi all,
My neighbour has a 5kW Aquarea K-Series and the Controller is in the hallway. However, the temperature is off by about 2 to 2.5 deg. I have looked all over the menus for an “Offset” item (and I asked ChatGPT) but I cannot find such an item anywhere.
His controller is one like this below. AI pointed towards the possibility of a hidden menu, but I couldn’t find any way of getting into it. All suggestions failed.
I somewhat expect that there must be a hidden menu, especially since cooling is not activated, and I am sure that the unit supports cooling
Thanks in advance
It’s OK. I found the hidden menu - BACK, ENTER & RIGHT simultaneously for about 10 secs, and indeed, in there was a menu where you could adjust the temperature sensors with a + or - 2deg
