Firstly just posting here as it seems more active than the OVMS forum… Please let me know if this isn’t right!
So I currently have a e-NV200 running OVMS V3 hardware which has been running for the past few months.
Our ICE failed it’s MOT so we are in the process of upgrading to a 2020 50 kWh Zoe.
I have a few questions!
Can I just connect the hardware to the Zoe using the leaf OBD cable just to try it out?
If I do this, is there way to backup the config so I can dump it back onto the hardware when it goes back into the env200? Will I have to re authorise with ABRP?
Has anyone got the ABRP running on multiple vehicles? Ie so the SOC is showing for the vehicle you are in. Is there a way to handle this?
For the Zoe Phase 2, I understand locking and precon need a deeper connection. I did quickly Google it, but I couldn’t see any guides on how to do this. Are there any?
The Open Vehicles documentation has a dedicated page for the Zoe Phase 2, and your 2020 50 kWh model is one. Two connection paths are documented there: standard OBD-II with the generic OBD-II to DB9 cable for basic monitoring, and a V-CAN tap into the BCM or gateway for the advanced features - remote preheat/cool and lock/unlock are marked as requiring the V-CAN connection. So your “deeper connection” guess is right, and that page is the guide you were looking for. On the Leaf cable: the docs specify the generic OBD-II to DB9 cable for the Zoe, so whether the Nissan-specific one is pin-compatible I cannot confirm - treat that part as unverified from my side.
You can try it, but I don’t think it will work. Nissan cable has got a different pinout compared to the Generic cable that the Zoe uses. You can compare the pinout on the product pages
I think you will need to order a Generic cable. Either Right or Left will work.
