Orca heat pump
I would like to share my work on managing an Orca heat pump—a Slovenian system that uses two Mitsubishi PUHZ-SHW outdoor units paired with a custom indoor unit from Orca.
Unfortunately, the two units were oversized for my needs. After spending a year learning the ins and outs of how to control them (given the lack of comprehensive documentation), and with the help of the integration found here:
I have managed to achieve my current setup using Home Assistant.
Essentially, I am now able to implement a weather-compensated heating curve, apply various operational strategies—such as night-time reduction—and trigger a domestic hot water (DHW) “boost” mode when my photovoltaic system is generating excess power. These and other minor adjustments have significantly improved the heat pump’s performance.
