I finally got around to loading the new firmware for OpenEVSE 7.1.3 on. Something I noticed on the display as it scrolls through. While charging there is one that says Left with a countdown occurring. I was wondering what the countdown represented. This is during my PV Divert charging. I was kind of thinking the time represented when sleep period would end due to the time override at night.
This time left display is used when using the time limit of scheduled charging feature. Did you have both a schedule charge and solar PV divert active? If a schedule charge was active, it should show the amount of time until the end schedule time
I do, so then it’s showing how long PV divert is left until the schedule takes over then. Ok, what I was thinking, but wasn’t sure.
