Hello,
could you tell me the types of data emoncms receives from openevse?
could you inform the api that communicates openevse with emoncms ?
Hi, thanks for your interest. Have you see our OpenEVSE setup guide for Emoncms:
Here is the data that get’s logged to Emoncms:
There is also an MQTT and HTTP API and the ability to send low level ‘RAPI’ commands to the OpenEVSE controller to control every aspect of the charger
Can I use this API to point to another service or is it emoncms specific ?
Try restarting the emonPi / EmonBase then try logging Inputs to Feeds again
I only use emoncms on my local server.
In the screenshot above you have a power_to_kwh process attached to the openevse pilot input logging to ev_current. This is not going to give good results. I would delete the ‘power_to_kwh’ process that you have added there…
Attached to the openevse:amp input this is the process list that I think you need:
I couldn’t find that openevse:amp entry.
would be in this same image that mentioned the error?
I really only need data from ev-energy, ev-current, ev-power and ev-temperature.
could that help?
