Hello, I have a openevse and used the Configure Device to integrte into EmonCMS. The kwh in the template looks wrong:
I’m no emoncms expert, but correct me if I’m wrong:
The input goes in in Wh and we are multiplying by 0.001, and then using the whacc we are accumulating. So, if we made a multiply by 0.001 the value becomes kwh and if we are then using the Watt Hour Accumulator, it does not seems correct.
Thank You
