Morning,
Hopefully this helps - I was watching the system over the weekend and have some more data…
I was away this weekend, so not much was happening in the house, and so there were no ‘incidents’ of missing data - until Sunday afternoon when we had 2 Octopus Free hours of electricity when I turned lots of things on to use the power (all of which are monitored).
During this time (13:00 - 15:00) there were many gaps in the data:
I also managed to get the emonHub log for some of the period.
I’m happy to upload the whole log if that helps, but as an example, around 14:00 I see this data from the feeds graph:
2026-11-01 13:59:30, 16150, 88, 8291
2026-11-01 13:59:45, 16071, 86, 8284
2026-11-01 14:00:00, 17009, 85, 8270
2026-11-01 14:00:15, null, null, null
2026-11-01 14:00:30, null, null, null
2026-11-01 14:00:45, null, null, null
2026-11-01 14:01:00, null, null, null
2026-11-01 14:01:15, 16395, 50, 8291
2026-11-01 14:01:30, 16188, 49, 8303
2026-11-01 14:01:45, 15929, 0, 8304
2026-11-01 14:02:00, 15660, 43, 8298
2026-11-01 14:02:15, 15433, 0, 8297
2026-11-01 14:02:30, 15293, 38, null
2026-11-01 14:02:45, null, null, null
2026-11-01 14:03:00, null, null, null
2026-11-01 14:03:15, null, null, null
2026-11-01 14:03:30, 14432, 45, 8415
2026-11-01 14:03:45, 14369, 49, 8415
and in the emonHub log
2026-11-01 13:59:50,096 DEBUG emoncmsorg Buffer size: 11
2026-11-01 13:59:52,100 DEBUG RFM2Pi 251887 NEW FRAME : OK 5 59 63 90 0 149 63 80 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 13:59:52,102 DEBUG RFM2Pi 251887 Timestamp : 1793541592.100119
2026-11-01 13:59:52,103 DEBUG RFM2Pi 251887 From Node : 5
2026-11-01 13:59:52,103 DEBUG RFM2Pi 251887 Values : [16187, 90, 16277, 223.52, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 13:59:52,104 DEBUG RFM2Pi 251887 Sent to channel(start)' : ToEmonCMS
2026-11-01 13:59:52,104 DEBUG RFM2Pi 251887 Sent to channel(end)' : ToEmonCMS
2026-11-01 13:59:52,129 DEBUG MQTT Publishing: emon/emonpi/power1 16187
2026-11-01 13:59:52,130 DEBUG MQTT Publishing: emon/emonpi/power2 90
2026-11-01 13:59:52,131 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16277
2026-11-01 13:59:52,132 DEBUG MQTT Publishing: emon/emonpi/vrms 223.52
2026-11-01 13:59:52,133 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 13:59:52,134 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 13:59:52,135 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 13:59:52,135 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 13:59:52,137 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 13:59:52,139 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 13:59:52,141 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 13:59:52,142 INFO MQTT Publishing 'node' formatted msg
2026-11-01 13:59:52,143 DEBUG MQTT Publishing: emonhub/rx/5/values 16187,90,16277,223.52,0,0,0,0,0,0,0
2026-11-01 13:59:55,927 DEBUG RFM2Pi 251888 NEW FRAME : OK 15 76 249 81 85 45 15 85 85 85 85 60 117 37 90 136 106 85 85 28 114 85 85 217 41 85 85 174 110 87 85 197 86 101 32 101 32 84 85 85 85 (-28)
2026-11-01 13:59:55,929 DEBUG RFM2Pi 251888 Timestamp : 1793541595.926892
2026-11-01 13:59:55,930 DEBUG RFM2Pi 251888 From Node : 15
2026-11-01 13:59:55,930 DEBUG RFM2Pi 251888 Values : [306201, 231.6, 0, 0, 8297, 3952, 16349, 10057, 31884, 146427, 9.120000000000001, 300, 300, 1, 1923, 3.131003940212967]
2026-11-01 13:59:55,931 DEBUG RFM2Pi 251888 RSSI : -28
2026-11-01 13:59:55,932 DEBUG RFM2Pi 251888 Sent to channel(start)' : ToEmonCMS
2026-11-01 13:59:55,932 DEBUG RFM2Pi 251888 Sent to channel(end)' : ToEmonCMS
2026-11-01 13:59:55,966 DEBUG MQTT Publishing: emon/emontx3cm15/MSG 306201
2026-11-01 13:59:55,968 DEBUG MQTT Publishing: emon/emontx3cm15/Vrms 231.6
2026-11-01 13:59:55,969 DEBUG MQTT Publishing: emon/emontx3cm15/P1 0
2026-11-01 13:59:55,970 DEBUG MQTT Publishing: emon/emontx3cm15/P2 0
2026-11-01 13:59:55,971 DEBUG MQTT Publishing: emon/emontx3cm15/P3 8297
2026-11-01 13:59:55,972 DEBUG MQTT Publishing: emon/emontx3cm15/P4 3952
2026-11-01 13:59:55,973 DEBUG MQTT Publishing: emon/emontx3cm15/E1 16349
2026-11-01 13:59:55,974 DEBUG MQTT Publishing: emon/emontx3cm15/E2 10057
2026-11-01 13:59:55,975 DEBUG MQTT Publishing: emon/emontx3cm15/E3 31884
2026-11-01 13:59:55,976 DEBUG MQTT Publishing: emon/emontx3cm15/E4 146427
2026-11-01 13:59:55,978 DEBUG MQTT Publishing: emon/emontx3cm15/T1 9.120000000000001
2026-11-01 13:59:55,979 DEBUG MQTT Publishing: emon/emontx3cm15/T2 300
2026-11-01 13:59:55,980 DEBUG MQTT Publishing: emon/emontx3cm15/T3 300
2026-11-01 13:59:55,981 DEBUG MQTT Publishing: emon/emontx3cm15/pulse 1
2026-11-01 13:59:55,983 DEBUG MQTT Publishing: emon/emontx3cm15/missed 1923
2026-11-01 13:59:55,984 DEBUG MQTT Publishing: emon/emontx3cm15/missedprc 3.131003940212967
2026-11-01 13:59:55,986 DEBUG MQTT Publishing: emon/emontx3cm15/rssi -28
2026-11-01 13:59:55,987 INFO MQTT Publishing 'node' formatted msg
2026-11-01 13:59:55,988 DEBUG MQTT Publishing: emonhub/rx/15/values 306201,231.6,0,0,8297,3952,16349,10057,31884,146427,9.120000000000001,300,300,1,1923,3.131003940212967,-28
2026-11-01 13:59:56,449 DEBUG RFM2Pi 251889 NEW FRAME : OK 16 228 239 81 85 14 13 218 86 85 85 85 85 85 85 26 182 80 85 244 71 85 85 149 13 186 170 91 88 85 85 101 32 101 32 101 32 90 85 85 85 (-33)
2026-11-01 13:59:56,451 DEBUG RFM2Pi 251889 Timestamp : 1793541596.449018
2026-11-01 13:59:56,452 DEBUG RFM2Pi 251889 From Node : 16
2026-11-01 13:59:56,453 DEBUG RFM2Pi 251889 Values : [309937, 226.19, 911, 0, 0, 0, 385871, 4769, 4293875904, 3342, 300, 300, 300, 15, 1871, 3.0096353370759408]
2026-11-01 13:59:56,453 DEBUG RFM2Pi 251889 RSSI : -33
2026-11-01 13:59:56,454 DEBUG RFM2Pi 251889 Sent to channel(start)' : ToEmonCMS
2026-11-01 13:59:56,454 DEBUG RFM2Pi 251889 Sent to channel(end)' : ToEmonCMS
2026-11-01 13:59:56,604 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 309937
2026-11-01 13:59:56,605 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 226.19
2026-11-01 13:59:56,607 DEBUG MQTT Publishing: emon/emontx3cm16/P1 911
2026-11-01 13:59:56,609 DEBUG MQTT Publishing: emon/emontx3cm16/P2 0
2026-11-01 13:59:56,611 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2026-11-01 13:59:56,613 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2026-11-01 13:59:56,614 DEBUG MQTT Publishing: emon/emontx3cm16/E1 385871
2026-11-01 13:59:56,617 DEBUG MQTT Publishing: emon/emontx3cm16/E2 4769
2026-11-01 13:59:56,618 DEBUG MQTT Publishing: emon/emontx3cm16/E3 4293875904
2026-11-01 13:59:56,620 DEBUG MQTT Publishing: emon/emontx3cm16/E4 3342
2026-11-01 13:59:56,621 DEBUG MQTT Publishing: emon/emontx3cm16/T1 300
2026-11-01 13:59:56,623 DEBUG MQTT Publishing: emon/emontx3cm16/T2 300
2026-11-01 13:59:56,624 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2026-11-01 13:59:56,626 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 15
2026-11-01 13:59:56,628 DEBUG MQTT Publishing: emon/emontx3cm16/missed 1871
2026-11-01 13:59:56,630 DEBUG MQTT Publishing: emon/emontx3cm16/missedprc 3.0096353370759408
2026-11-01 13:59:56,631 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -33
2026-11-01 13:59:56,633 INFO MQTT Publishing 'node' formatted msg
2026-11-01 13:59:56,634 DEBUG MQTT Publishing: emonhub/rx/16/values 309937,226.19,911,0,0,0,385871,4769,4293875904,3342,300,300,300,15,1871,3.0096353370759408,-33
2026-11-01 13:59:57,065 DEBUG RFM2Pi 251890 NEW FRAME : OK 5 134 66 87 0 221 66 41 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 13:59:57,068 DEBUG RFM2Pi 251890 Timestamp : 1793541597.065243
2026-11-01 13:59:57,068 DEBUG RFM2Pi 251890 From Node : 5
2026-11-01 13:59:57,070 DEBUG RFM2Pi 251890 Values : [17030, 87, 17117, 223.13, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 13:59:57,071 DEBUG RFM2Pi 251890 Sent to channel(start)' : ToEmonCMS
2026-11-01 13:59:57,072 DEBUG RFM2Pi 251890 Sent to channel(end)' : ToEmonCMS
2026-11-01 13:59:57,177 DEBUG RFM2Pi 251891 NEW FRAME : OK 23 182 0 12 1 12 1 21 1 244 1 11 0 1 0 0 0 (-61)
2026-11-01 13:59:57,178 DEBUG RFM2Pi 251891 Timestamp : 1793541597.176801
2026-11-01 13:59:57,179 DEBUG RFM2Pi 251891 From Node : 23
2026-11-01 13:59:57,180 DEBUG RFM2Pi 251891 Values : [18.2, 26.8, 26.8, 27.700000000000003, 50, 1.1, 1]
2026-11-01 13:59:57,181 DEBUG RFM2Pi 251891 RSSI : -61
2026-11-01 13:59:57,181 DEBUG RFM2Pi 251891 Sent to channel(start)' : ToEmonCMS
2026-11-01 13:59:57,182 DEBUG RFM2Pi 251891 Sent to channel(end)' : ToEmonCMS
2026-11-01 13:59:57,247 DEBUG MQTT Publishing: emon/emonpi/power1 17030
2026-11-01 13:59:57,248 DEBUG MQTT Publishing: emon/emonpi/power2 87
2026-11-01 13:59:57,250 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 17117
2026-11-01 13:59:57,251 DEBUG MQTT Publishing: emon/emonpi/vrms 223.13
2026-11-01 13:59:57,252 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 13:59:57,253 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 13:59:57,254 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 13:59:57,256 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 13:59:57,258 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 13:59:57,260 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 13:59:57,262 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 13:59:57,264 INFO MQTT Publishing 'node' formatted msg
2026-11-01 13:59:57,265 DEBUG MQTT Publishing: emonhub/rx/5/values 17030,87,17117,223.13,0,0,0,0,0,0,0
2026-11-01 13:59:57,372 DEBUG MQTT Publishing: emon/emonth_3ext/temperature 18.2
2026-11-01 13:59:57,374 DEBUG MQTT Publishing: emon/emonth_3ext/ext1 26.8
2026-11-01 13:59:57,375 DEBUG MQTT Publishing: emon/emonth_3ext/ext2 26.8
2026-11-01 13:59:57,377 DEBUG MQTT Publishing: emon/emonth_3ext/ext3 27.700000000000003
2026-11-01 13:59:57,379 DEBUG MQTT Publishing: emon/emonth_3ext/humidity 50
2026-11-01 13:59:57,380 DEBUG MQTT Publishing: emon/emonth_3ext/battery 1.1
2026-11-01 13:59:57,381 DEBUG MQTT Publishing: emon/emonth_3ext/pulsecount 1
2026-11-01 13:59:57,382 DEBUG MQTT Publishing: emon/emonth_3ext/rssi -61
2026-11-01 13:59:57,383 INFO MQTT Publishing 'node' formatted msg
2026-11-01 13:59:57,383 DEBUG MQTT Publishing: emonhub/rx/23/values 18.2,26.8,26.8,27.700000000000003,50,1.1,1,-61
2026-11-01 14:00:02,147 DEBUG RFM2Pi 251892 NEW FRAME : OK 5 113 66 85 0 198 66 19 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:02,151 DEBUG RFM2Pi 251892 Timestamp : 1793541602.147557
2026-11-01 14:00:02,152 DEBUG RFM2Pi 251892 From Node : 5
2026-11-01 14:00:02,152 DEBUG RFM2Pi 251892 Values : [17009, 85, 17094, 222.91, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:02,153 DEBUG RFM2Pi 251892 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:02,154 DEBUG RFM2Pi 251892 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:02,222 DEBUG MQTT Publishing: emon/emonpi/power1 17009
2026-11-01 14:00:02,224 DEBUG MQTT Publishing: emon/emonpi/power2 85
2026-11-01 14:00:02,225 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 17094
2026-11-01 14:00:02,227 DEBUG MQTT Publishing: emon/emonpi/vrms 222.91
2026-11-01 14:00:02,228 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:02,229 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:02,230 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:02,231 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:02,233 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:02,234 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:02,235 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:02,236 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:02,237 DEBUG MQTT Publishing: emonhub/rx/5/values 17009,85,17094,222.91,0,0,0,0,0,0,0
2026-11-01 14:00:05,881 DEBUG RFM2Pi 251893 NEW FRAME : OK 15 79 249 81 85 1 15 85 85 85 85 27 117 63 90 136 106 85 85 28 114 85 85 246 41 85 85 83 105 87 85 197 86 101 32 101 32 84 85 85 85 (-28)
2026-11-01 14:00:05,882 DEBUG RFM2Pi 251893 Timestamp : 1793541605.880869
2026-11-01 14:00:05,882 DEBUG RFM2Pi 251893 From Node : 15
2026-11-01 14:00:05,882 DEBUG RFM2Pi 251893 Values : [306202, 231.24, 0, 0, 8270, 3946, 16349, 10057, 31907, 146438, 9.120000000000001, 300, 300, 1, 1923, 3.130952962438333]
2026-11-01 14:00:05,883 DEBUG RFM2Pi 251893 RSSI : -28
2026-11-01 14:00:05,883 DEBUG RFM2Pi 251893 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:05,883 DEBUG RFM2Pi 251893 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:06,068 DEBUG MQTT Publishing: emon/emontx3cm15/MSG 306202
2026-11-01 14:00:06,069 DEBUG MQTT Publishing: emon/emontx3cm15/Vrms 231.24
2026-11-01 14:00:06,070 DEBUG MQTT Publishing: emon/emontx3cm15/P1 0
2026-11-01 14:00:06,070 DEBUG MQTT Publishing: emon/emontx3cm15/P2 0
2026-11-01 14:00:06,071 DEBUG MQTT Publishing: emon/emontx3cm15/P3 8270
2026-11-01 14:00:06,071 DEBUG MQTT Publishing: emon/emontx3cm15/P4 3946
2026-11-01 14:00:06,072 DEBUG MQTT Publishing: emon/emontx3cm15/E1 16349
2026-11-01 14:00:06,073 DEBUG MQTT Publishing: emon/emontx3cm15/E2 10057
2026-11-01 14:00:06,073 DEBUG MQTT Publishing: emon/emontx3cm15/E3 31907
2026-11-01 14:00:06,074 DEBUG MQTT Publishing: emon/emontx3cm15/E4 146438
2026-11-01 14:00:06,075 DEBUG MQTT Publishing: emon/emontx3cm15/T1 9.120000000000001
2026-11-01 14:00:06,075 DEBUG MQTT Publishing: emon/emontx3cm15/T2 300
2026-11-01 14:00:06,076 DEBUG MQTT Publishing: emon/emontx3cm15/T3 300
2026-11-01 14:00:06,077 DEBUG MQTT Publishing: emon/emontx3cm15/pulse 1
2026-11-01 14:00:06,078 DEBUG MQTT Publishing: emon/emontx3cm15/missed 1923
2026-11-01 14:00:06,078 DEBUG MQTT Publishing: emon/emontx3cm15/missedprc 3.130952962438333
2026-11-01 14:00:06,079 DEBUG MQTT Publishing: emon/emontx3cm15/rssi -28
2026-11-01 14:00:06,080 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:06,080 DEBUG MQTT Publishing: emonhub/rx/15/values 306202,231.24,0,0,8270,3946,16349,10057,31907,146438,9.120000000000001,300,300,1,1923,3.130952962438333,-28
2026-11-01 14:00:06,304 DEBUG RFM2Pi 251894 NEW FRAME : OK 16 231 239 81 85 107 13 200 86 85 85 85 85 85 85 4 182 80 85 244 71 85 85 149 13 186 170 91 88 85 85 101 32 101 32 101 32 90 85 85 85 (-34)
2026-11-01 14:00:06,315 DEBUG RFM2Pi 251894 Timestamp : 1793541606.304030
2026-11-01 14:00:06,317 DEBUG RFM2Pi 251894 From Node : 16
2026-11-01 14:00:06,318 DEBUG RFM2Pi 251894 Values : [309938, 225.9, 925, 0, 0, 0, 385873, 4769, 4293875904, 3342, 300, 300, 300, 15, 1871, 3.009586925749582]
2026-11-01 14:00:06,319 DEBUG RFM2Pi 251894 RSSI : -34
2026-11-01 14:00:06,320 DEBUG RFM2Pi 251894 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:06,321 DEBUG RFM2Pi 251894 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:06,416 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 309938
2026-11-01 14:00:06,418 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 225.9
2026-11-01 14:00:06,419 DEBUG MQTT Publishing: emon/emontx3cm16/P1 925
2026-11-01 14:00:06,421 DEBUG MQTT Publishing: emon/emontx3cm16/P2 0
2026-11-01 14:00:06,423 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2026-11-01 14:00:06,425 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2026-11-01 14:00:06,430 DEBUG MQTT Publishing: emon/emontx3cm16/E1 385873
2026-11-01 14:00:06,433 DEBUG MQTT Publishing: emon/emontx3cm16/E2 4769
2026-11-01 14:00:06,435 DEBUG MQTT Publishing: emon/emontx3cm16/E3 4293875904
2026-11-01 14:00:06,438 DEBUG MQTT Publishing: emon/emontx3cm16/E4 3342
2026-11-01 14:00:06,440 DEBUG MQTT Publishing: emon/emontx3cm16/T1 300
2026-11-01 14:00:06,443 DEBUG MQTT Publishing: emon/emontx3cm16/T2 300
2026-11-01 14:00:06,447 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2026-11-01 14:00:06,452 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 15
2026-11-01 14:00:06,458 DEBUG MQTT Publishing: emon/emontx3cm16/missed 1871
2026-11-01 14:00:06,459 DEBUG MQTT Publishing: emon/emontx3cm16/missedprc 3.009586925749582
2026-11-01 14:00:06,461 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -34
2026-11-01 14:00:06,462 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:06,463 DEBUG MQTT Publishing: emonhub/rx/16/values 309938,225.9,925,0,0,0,385873,4769,4293875904,3342,300,300,300,15,1871,3.009586925749582,-34
2026-11-01 14:00:07,141 DEBUG RFM2Pi 251895 NEW FRAME : OK 5 97 63 89 0 186 63 72 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:07,143 DEBUG RFM2Pi 251895 Timestamp : 1793541607.141264
2026-11-01 14:00:07,144 DEBUG RFM2Pi 251895 From Node : 5
2026-11-01 14:00:07,145 DEBUG RFM2Pi 251895 Values : [16225, 89, 16314, 223.44, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:07,146 DEBUG RFM2Pi 251895 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:07,147 DEBUG RFM2Pi 251895 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:07,275 DEBUG MQTT Publishing: emon/emonpi/power1 16225
2026-11-01 14:00:07,277 DEBUG MQTT Publishing: emon/emonpi/power2 89
2026-11-01 14:00:07,278 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16314
2026-11-01 14:00:07,280 DEBUG MQTT Publishing: emon/emonpi/vrms 223.44
2026-11-01 14:00:07,281 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:07,282 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:07,283 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:07,284 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:07,285 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:07,287 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:07,288 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:07,289 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:07,290 DEBUG MQTT Publishing: emonhub/rx/5/values 16225,89,16314,223.44,0,0,0,0,0,0,0
2026-11-01 14:00:12,080 DEBUG RFM2Pi 251896 NEW FRAME : OK 5 219 63 83 0 46 64 66 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:12,082 DEBUG RFM2Pi 251896 Timestamp : 1793541612.080115
2026-11-01 14:00:12,083 DEBUG RFM2Pi 251896 From Node : 5
2026-11-01 14:00:12,083 DEBUG RFM2Pi 251896 Values : [16347, 83, 16430, 223.38, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:12,084 DEBUG RFM2Pi 251896 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:12,084 DEBUG RFM2Pi 251896 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:12,237 DEBUG MQTT Publishing: emon/emonpi/power1 16347
2026-11-01 14:00:12,239 DEBUG MQTT Publishing: emon/emonpi/power2 83
2026-11-01 14:00:12,241 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16430
2026-11-01 14:00:12,242 DEBUG MQTT Publishing: emon/emonpi/vrms 223.38
2026-11-01 14:00:12,243 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:12,245 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:12,246 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:12,248 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:12,250 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:12,251 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:12,255 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:12,257 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:12,258 DEBUG MQTT Publishing: emonhub/rx/5/values 16347,83,16430,223.38,0,0,0,0,0,0,0
2026-11-01 14:00:15,808 DEBUG RFM2Pi 251897 NEW FRAME : OK 15 78 249 81 85 218 15 85 85 85 85 45 117 32 90 136 106 85 85 28 114 85 85 239 41 85 85 68 105 87 85 197 86 101 32 101 32 84 85 85 85 (-28)
2026-11-01 14:00:15,811 DEBUG RFM2Pi 251897 Timestamp : 1793541615.808138
2026-11-01 14:00:15,811 DEBUG RFM2Pi 251897 From Node : 15
2026-11-01 14:00:15,812 DEBUG RFM2Pi 251897 Values : [306203, 231.83, 0, 0, 8312, 3957, 16349, 10057, 31930, 146449, 9.120000000000001, 300, 300, 1, 1923, 3.130901986323673]
2026-11-01 14:00:15,813 DEBUG RFM2Pi 251897 RSSI : -28
2026-11-01 14:00:15,813 DEBUG RFM2Pi 251897 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:15,814 DEBUG RFM2Pi 251897 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:15,883 DEBUG MQTT Publishing: emon/emontx3cm15/MSG 306203
2026-11-01 14:00:15,884 DEBUG MQTT Publishing: emon/emontx3cm15/Vrms 231.83
2026-11-01 14:00:15,885 DEBUG MQTT Publishing: emon/emontx3cm15/P1 0
2026-11-01 14:00:15,887 DEBUG MQTT Publishing: emon/emontx3cm15/P2 0
2026-11-01 14:00:15,888 DEBUG MQTT Publishing: emon/emontx3cm15/P3 8312
2026-11-01 14:00:15,889 DEBUG MQTT Publishing: emon/emontx3cm15/P4 3957
2026-11-01 14:00:15,890 DEBUG MQTT Publishing: emon/emontx3cm15/E1 16349
2026-11-01 14:00:15,891 DEBUG MQTT Publishing: emon/emontx3cm15/E2 10057
2026-11-01 14:00:15,892 DEBUG MQTT Publishing: emon/emontx3cm15/E3 31930
2026-11-01 14:00:15,893 DEBUG MQTT Publishing: emon/emontx3cm15/E4 146449
2026-11-01 14:00:15,895 DEBUG MQTT Publishing: emon/emontx3cm15/T1 9.120000000000001
2026-11-01 14:00:15,896 DEBUG MQTT Publishing: emon/emontx3cm15/T2 300
2026-11-01 14:00:15,897 DEBUG MQTT Publishing: emon/emontx3cm15/T3 300
2026-11-01 14:00:15,898 DEBUG MQTT Publishing: emon/emontx3cm15/pulse 1
2026-11-01 14:00:15,899 DEBUG MQTT Publishing: emon/emontx3cm15/missed 1923
2026-11-01 14:00:15,900 DEBUG MQTT Publishing: emon/emontx3cm15/missedprc 3.130901986323673
2026-11-01 14:00:15,901 DEBUG MQTT Publishing: emon/emontx3cm15/rssi -28
2026-11-01 14:00:15,902 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:15,903 DEBUG MQTT Publishing: emonhub/rx/15/values 306203,231.83,0,0,8312,3957,16349,10057,31930,146449,9.120000000000001,300,300,1,1923,3.130901986323673,-28
2026-11-01 14:00:16,124 DEBUG RFM2Pi 251898 NEW FRAME : OK 16 230 239 81 85 33 13 244 86 85 85 85 85 85 85 1 182 80 85 244 71 85 85 149 13 186 170 91 88 85 85 101 32 101 32 101 32 90 85 85 85 (-33)
2026-11-01 14:00:16,126 DEBUG RFM2Pi 251898 Timestamp : 1793541616.123900
2026-11-01 14:00:16,127 DEBUG RFM2Pi 251898 From Node : 16
2026-11-01 14:00:16,127 DEBUG RFM2Pi 251898 Values : [309939, 226.44, 929, 0, 0, 0, 385876, 4769, 4293875904, 3342, 300, 300, 300, 15, 1871, 3.0095385159806334]
2026-11-01 14:00:16,128 DEBUG RFM2Pi 251898 RSSI : -33
2026-11-01 14:00:16,129 DEBUG RFM2Pi 251898 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:16,129 DEBUG RFM2Pi 251898 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:16,315 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 309939
2026-11-01 14:00:16,317 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 226.44
2026-11-01 14:00:16,319 DEBUG MQTT Publishing: emon/emontx3cm16/P1 929
2026-11-01 14:00:16,321 DEBUG MQTT Publishing: emon/emontx3cm16/P2 0
2026-11-01 14:00:16,323 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2026-11-01 14:00:16,324 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2026-11-01 14:00:16,325 DEBUG MQTT Publishing: emon/emontx3cm16/E1 385876
2026-11-01 14:00:16,327 DEBUG MQTT Publishing: emon/emontx3cm16/E2 4769
2026-11-01 14:00:16,328 DEBUG MQTT Publishing: emon/emontx3cm16/E3 4293875904
2026-11-01 14:00:16,329 DEBUG MQTT Publishing: emon/emontx3cm16/E4 3342
2026-11-01 14:00:16,331 DEBUG MQTT Publishing: emon/emontx3cm16/T1 300
2026-11-01 14:00:16,332 DEBUG MQTT Publishing: emon/emontx3cm16/T2 300
2026-11-01 14:00:16,334 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2026-11-01 14:00:16,335 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 15
2026-11-01 14:00:16,337 DEBUG MQTT Publishing: emon/emontx3cm16/missed 1871
2026-11-01 14:00:16,338 DEBUG MQTT Publishing: emon/emontx3cm16/missedprc 3.0095385159806334
2026-11-01 14:00:16,340 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -33
2026-11-01 14:00:16,341 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:16,342 DEBUG MQTT Publishing: emonhub/rx/16/values 309939,226.44,929,0,0,0,385876,4769,4293875904,3342,300,300,300,15,1871,3.0095385159806334,-33
2026-11-01 14:00:17,139 DEBUG RFM2Pi 251899 NEW FRAME : OK 5 17 64 77 0 94 64 121 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:17,141 DEBUG RFM2Pi 251899 Timestamp : 1793541617.138978
2026-11-01 14:00:17,142 DEBUG RFM2Pi 251899 From Node : 5
2026-11-01 14:00:17,142 DEBUG RFM2Pi 251899 Values : [16401, 77, 16478, 223.93, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:17,143 DEBUG RFM2Pi 251899 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:17,143 DEBUG RFM2Pi 251899 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:17,260 DEBUG MQTT Publishing: emon/emonpi/power1 16401
2026-11-01 14:00:17,262 DEBUG MQTT Publishing: emon/emonpi/power2 77
2026-11-01 14:00:17,263 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16478
2026-11-01 14:00:17,264 DEBUG MQTT Publishing: emon/emonpi/vrms 223.93
2026-11-01 14:00:17,265 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:17,267 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:17,268 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:17,269 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:17,270 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:17,271 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:17,272 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:17,273 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:17,274 DEBUG MQTT Publishing: emonhub/rx/5/values 16401,77,16478,223.93,0,0,0,0,0,0,0
2026-11-01 14:00:20,148 DEBUG emoncmsorg Buffer size: 13
2026-11-01 14:00:22,079 DEBUG RFM2Pi 251900 NEW FRAME : OK 5 158 63 76 0 234 63 104 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:22,081 DEBUG RFM2Pi 251900 Timestamp : 1793541622.078872
2026-11-01 14:00:22,081 DEBUG RFM2Pi 251900 From Node : 5
2026-11-01 14:00:22,082 DEBUG RFM2Pi 251900 Values : [16286, 76, 16362, 223.76, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:22,082 DEBUG RFM2Pi 251900 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:22,083 DEBUG RFM2Pi 251900 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:22,296 DEBUG MQTT Publishing: emon/emonpi/power1 16286
2026-11-01 14:00:22,298 DEBUG MQTT Publishing: emon/emonpi/power2 76
2026-11-01 14:00:22,299 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16362
2026-11-01 14:00:22,300 DEBUG MQTT Publishing: emon/emonpi/vrms 223.76
2026-11-01 14:00:22,301 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:22,301 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:22,302 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:22,303 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:22,304 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:22,305 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:22,306 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:22,308 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:22,308 DEBUG MQTT Publishing: emonhub/rx/5/values 16286,76,16362,223.76,0,0,0,0,0,0,0
2026-11-01 14:00:25,800 DEBUG RFM2Pi 251901 NEW FRAME : OK 15 73 249 81 85 203 15 85 85 85 85 215 117 34 90 136 106 85 85 28 114 85 85 132 41 85 85 73 105 87 85 197 86 101 32 101 32 84 85 85 85 (-28)
2026-11-01 14:00:25,801 DEBUG RFM2Pi 251901 Timestamp : 1793541625.800189
2026-11-01 14:00:25,801 DEBUG RFM2Pi 251901 From Node : 15
2026-11-01 14:00:25,802 DEBUG RFM2Pi 251901 Values : [306204, 231.98000000000002, 0, 0, 8322, 3959, 16349, 10057, 31953, 146460, 9.120000000000001, 300, 300, 1, 1923, 3.130851011868905]
2026-11-01 14:00:25,802 DEBUG RFM2Pi 251901 RSSI : -28
2026-11-01 14:00:25,802 DEBUG RFM2Pi 251901 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:25,802 DEBUG RFM2Pi 251901 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:25,907 DEBUG RFM2Pi 251902 NEW FRAME : OK 16 225 239 81 85 215 13 241 86 85 85 85 85 85 85 3 182 80 85 244 71 85 85 149 13 186 170 91 88 85 85 101 32 101 32 101 32 90 85 85 85 (-33)
2026-11-01 14:00:25,908 DEBUG RFM2Pi 251902 Timestamp : 1793541625.907258
2026-11-01 14:00:25,908 DEBUG RFM2Pi 251902 From Node : 16
2026-11-01 14:00:25,909 DEBUG RFM2Pi 251902 Values : [309940, 226.58, 932, 0, 0, 0, 385878, 4769, 4293875904, 3342, 300, 300, 300, 15, 1871, 3.0094901077690204]
2026-11-01 14:00:25,909 DEBUG RFM2Pi 251902 RSSI : -33
2026-11-01 14:00:25,909 DEBUG RFM2Pi 251902 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:25,909 DEBUG RFM2Pi 251902 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:25,929 DEBUG MQTT Publishing: emon/emontx3cm15/MSG 306204
2026-11-01 14:00:25,930 DEBUG MQTT Publishing: emon/emontx3cm15/Vrms 231.98000000000002
2026-11-01 14:00:25,930 DEBUG MQTT Publishing: emon/emontx3cm15/P1 0
2026-11-01 14:00:25,931 DEBUG MQTT Publishing: emon/emontx3cm15/P2 0
2026-11-01 14:00:25,932 DEBUG MQTT Publishing: emon/emontx3cm15/P3 8322
2026-11-01 14:00:25,933 DEBUG MQTT Publishing: emon/emontx3cm15/P4 3959
2026-11-01 14:00:25,933 DEBUG MQTT Publishing: emon/emontx3cm15/E1 16349
2026-11-01 14:00:25,934 DEBUG MQTT Publishing: emon/emontx3cm15/E2 10057
2026-11-01 14:00:25,935 DEBUG MQTT Publishing: emon/emontx3cm15/E3 31953
2026-11-01 14:00:25,935 DEBUG MQTT Publishing: emon/emontx3cm15/E4 146460
2026-11-01 14:00:25,936 DEBUG MQTT Publishing: emon/emontx3cm15/T1 9.120000000000001
2026-11-01 14:00:25,937 DEBUG MQTT Publishing: emon/emontx3cm15/T2 300
2026-11-01 14:00:25,938 DEBUG MQTT Publishing: emon/emontx3cm15/T3 300
2026-11-01 14:00:25,938 DEBUG MQTT Publishing: emon/emontx3cm15/pulse 1
2026-11-01 14:00:25,939 DEBUG MQTT Publishing: emon/emontx3cm15/missed 1923
2026-11-01 14:00:25,940 DEBUG MQTT Publishing: emon/emontx3cm15/missedprc 3.130851011868905
2026-11-01 14:00:25,941 DEBUG MQTT Publishing: emon/emontx3cm15/rssi -28
2026-11-01 14:00:25,941 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:25,942 DEBUG MQTT Publishing: emonhub/rx/15/values 306204,231.98000000000002,0,0,8322,3959,16349,10057,31953,146460,9.120000000000001,300,300,1,1923,3.130851011868905,-28
2026-11-01 14:00:26,149 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 309940
2026-11-01 14:00:26,150 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 226.58
2026-11-01 14:00:26,151 DEBUG MQTT Publishing: emon/emontx3cm16/P1 932
2026-11-01 14:00:26,151 DEBUG MQTT Publishing: emon/emontx3cm16/P2 0
2026-11-01 14:00:26,152 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2026-11-01 14:00:26,153 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2026-11-01 14:00:26,153 DEBUG MQTT Publishing: emon/emontx3cm16/E1 385878
2026-11-01 14:00:26,154 DEBUG MQTT Publishing: emon/emontx3cm16/E2 4769
2026-11-01 14:00:26,155 DEBUG MQTT Publishing: emon/emontx3cm16/E3 4293875904
2026-11-01 14:00:26,155 DEBUG MQTT Publishing: emon/emontx3cm16/E4 3342
2026-11-01 14:00:26,156 DEBUG MQTT Publishing: emon/emontx3cm16/T1 300
2026-11-01 14:00:26,157 DEBUG MQTT Publishing: emon/emontx3cm16/T2 300
2026-11-01 14:00:26,157 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2026-11-01 14:00:26,157 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 15
2026-11-01 14:00:26,158 DEBUG MQTT Publishing: emon/emontx3cm16/missed 1871
2026-11-01 14:00:26,158 DEBUG MQTT Publishing: emon/emontx3cm16/missedprc 3.0094901077690204
2026-11-01 14:00:26,158 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -33
2026-11-01 14:00:26,159 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:26,159 DEBUG MQTT Publishing: emonhub/rx/16/values 309940,226.58,932,0,0,0,385878,4769,4293875904,3342,300,300,300,15,1871,3.0094901077690204,-33
2026-11-01 14:00:27,123 DEBUG RFM2Pi 251903 NEW FRAME : OK 5 30 64 75 0 105 64 75 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:27,125 DEBUG RFM2Pi 251903 Timestamp : 1793541627.123155
2026-11-01 14:00:27,126 DEBUG RFM2Pi 251903 From Node : 5
2026-11-01 14:00:27,126 DEBUG RFM2Pi 251903 Values : [16414, 75, 16489, 223.47, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:27,127 DEBUG RFM2Pi 251903 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:27,128 DEBUG RFM2Pi 251903 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:27,279 DEBUG MQTT Publishing: emon/emonpi/power1 16414
2026-11-01 14:00:27,280 DEBUG MQTT Publishing: emon/emonpi/power2 75
2026-11-01 14:00:27,282 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16489
2026-11-01 14:00:27,283 DEBUG MQTT Publishing: emon/emonpi/vrms 223.47
2026-11-01 14:00:27,284 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:27,285 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:27,286 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:27,287 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:27,288 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:27,290 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:27,291 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:27,292 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:27,293 DEBUG MQTT Publishing: emonhub/rx/5/values 16414,75,16489,223.47,0,0,0,0,0,0,0
2026-11-01 14:00:32,052 DEBUG RFM2Pi 251904 NEW FRAME : OK 5 57 64 71 0 128 64 113 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:32,054 DEBUG RFM2Pi 251904 Timestamp : 1793541632.052247
2026-11-01 14:00:32,055 DEBUG RFM2Pi 251904 From Node : 5
2026-11-01 14:00:32,055 DEBUG RFM2Pi 251904 Values : [16441, 71, 16512, 223.85, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:32,056 DEBUG RFM2Pi 251904 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:32,057 DEBUG RFM2Pi 251904 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:32,117 DEBUG MQTT Publishing: emon/emonpi/power1 16441
2026-11-01 14:00:32,118 DEBUG MQTT Publishing: emon/emonpi/power2 71
2026-11-01 14:00:32,119 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16512
2026-11-01 14:00:32,120 DEBUG MQTT Publishing: emon/emonpi/vrms 223.85
2026-11-01 14:00:32,121 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:32,122 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:32,123 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:32,124 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:32,125 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:32,126 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:32,128 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:32,130 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:32,130 DEBUG MQTT Publishing: emonhub/rx/5/values 16441,71,16512,223.85,0,0,0,0,0,0,0
2026-11-01 14:00:35,676 DEBUG RFM2Pi 251905 NEW FRAME : OK 15 72 249 81 85 192 15 85 85 85 85 46 117 35 90 136 106 85 85 28 114 85 85 189 41 85 85 114 105 87 85 197 86 101 32 101 32 84 85 85 85 (-28)
2026-11-01 14:00:35,678 DEBUG RFM2Pi 251905 Timestamp : 1793541635.675718
2026-11-01 14:00:35,679 DEBUG RFM2Pi 251905 From Node : 15
2026-11-01 14:00:35,680 DEBUG RFM2Pi 251905 Values : [306205, 231.89000000000001, 0, 0, 8315, 3958, 16349, 10057, 31976, 146471, 9.120000000000001, 300, 300, 1, 1923, 3.1308000390739474]
2026-11-01 14:00:35,681 DEBUG RFM2Pi 251905 RSSI : -28
2026-11-01 14:00:35,682 DEBUG RFM2Pi 251905 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:35,683 DEBUG RFM2Pi 251905 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:35,952 DEBUG MQTT Publishing: emon/emontx3cm15/MSG 306205
2026-11-01 14:00:35,954 DEBUG MQTT Publishing: emon/emontx3cm15/Vrms 231.89000000000001
2026-11-01 14:00:35,955 DEBUG MQTT Publishing: emon/emontx3cm15/P1 0
2026-11-01 14:00:35,955 DEBUG MQTT Publishing: emon/emontx3cm15/P2 0
2026-11-01 14:00:35,957 DEBUG MQTT Publishing: emon/emontx3cm15/P3 8315
2026-11-01 14:00:35,959 DEBUG MQTT Publishing: emon/emontx3cm15/P4 3958
2026-11-01 14:00:35,960 DEBUG MQTT Publishing: emon/emontx3cm15/E1 16349
2026-11-01 14:00:35,961 DEBUG MQTT Publishing: emon/emontx3cm15/E2 10057
2026-11-01 14:00:35,963 DEBUG MQTT Publishing: emon/emontx3cm15/E3 31976
2026-11-01 14:00:35,964 DEBUG MQTT Publishing: emon/emontx3cm15/E4 146471
2026-11-01 14:00:35,966 DEBUG MQTT Publishing: emon/emontx3cm15/T1 9.120000000000001
2026-11-01 14:00:35,967 DEBUG MQTT Publishing: emon/emontx3cm15/T2 300
2026-11-01 14:00:35,968 DEBUG MQTT Publishing: emon/emontx3cm15/T3 300
2026-11-01 14:00:35,970 DEBUG MQTT Publishing: emon/emontx3cm15/pulse 1
2026-11-01 14:00:35,971 DEBUG MQTT Publishing: emon/emontx3cm15/missed 1923
2026-11-01 14:00:35,973 DEBUG MQTT Publishing: emon/emontx3cm15/missedprc 3.1308000390739474
2026-11-01 14:00:35,974 DEBUG MQTT Publishing: emon/emontx3cm15/rssi -28
2026-11-01 14:00:35,975 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:35,976 DEBUG MQTT Publishing: emonhub/rx/15/values 306205,231.89000000000001,0,0,8315,3958,16349,10057,31976,146471,9.120000000000001,300,300,1,1923,3.1308000390739474,-28
2026-11-01 14:00:37,092 DEBUG RFM2Pi 251906 NEW FRAME : OK 5 246 63 69 0 59 64 113 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:37,094 DEBUG RFM2Pi 251906 Timestamp : 1793541637.092694
2026-11-01 14:00:37,095 DEBUG RFM2Pi 251906 From Node : 5
2026-11-01 14:00:37,096 DEBUG RFM2Pi 251906 Values : [16374, 69, 16443, 223.85, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:37,096 DEBUG RFM2Pi 251906 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:37,097 DEBUG RFM2Pi 251906 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:37,289 DEBUG MQTT Publishing: emon/emonpi/power1 16374
2026-11-01 14:00:37,290 DEBUG MQTT Publishing: emon/emonpi/power2 69
2026-11-01 14:00:37,291 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16443
2026-11-01 14:00:37,293 DEBUG MQTT Publishing: emon/emonpi/vrms 223.85
2026-11-01 14:00:37,294 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:37,295 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:37,296 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:37,297 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:37,299 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:37,300 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:37,301 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:37,303 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:37,303 DEBUG MQTT Publishing: emonhub/rx/5/values 16374,69,16443,223.85,0,0,0,0,0,0,0
2026-11-01 14:00:42,119 DEBUG RFM2Pi 251907 NEW FRAME : OK 5 82 64 63 0 145 64 103 87 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:42,121 DEBUG RFM2Pi 251907 Timestamp : 1793541642.118907
2026-11-01 14:00:42,121 DEBUG RFM2Pi 251907 From Node : 5
2026-11-01 14:00:42,122 DEBUG RFM2Pi 251907 Values : [16466, 63, 16529, 223.75, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:42,123 DEBUG RFM2Pi 251907 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:42,123 DEBUG RFM2Pi 251907 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:42,327 DEBUG MQTT Publishing: emon/emonpi/power1 16466
2026-11-01 14:00:42,329 DEBUG MQTT Publishing: emon/emonpi/power2 63
2026-11-01 14:00:42,330 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16529
2026-11-01 14:00:42,331 DEBUG MQTT Publishing: emon/emonpi/vrms 223.75
2026-11-01 14:00:42,332 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:42,333 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:42,335 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:42,336 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:42,337 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:42,338 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:42,339 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:42,341 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:42,341 DEBUG MQTT Publishing: emonhub/rx/5/values 16466,63,16529,223.75,0,0,0,0,0,0,0
2026-11-01 14:00:45,654 DEBUG RFM2Pi 251908 NEW FRAME : OK 16 227 239 81 85 215 13 254 86 85 85 85 85 85 85 14 182 80 85 244 71 85 85 149 13 186 170 91 88 85 85 101 32 101 32 101 32 90 85 85 85 (-29)
2026-11-01 14:00:45,657 DEBUG RFM2Pi 251908 Timestamp : 1793541645.654485
2026-11-01 14:00:45,659 DEBUG RFM2Pi 251908 From Node : 16
2026-11-01 14:00:45,660 DEBUG RFM2Pi 251908 Values : [309942, 226.58, 939, 0, 0, 0, 385883, 4769, 4293875904, 3342, 300, 300, 300, 15, 1872, 3.011001737116387]
2026-11-01 14:00:45,667 DEBUG RFM2Pi 251908 RSSI : -29
2026-11-01 14:00:45,668 DEBUG RFM2Pi 251908 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:45,669 DEBUG RFM2Pi 251908 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:45,768 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 309942
2026-11-01 14:00:45,769 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 226.58
2026-11-01 14:00:45,770 DEBUG MQTT Publishing: emon/emontx3cm16/P1 939
2026-11-01 14:00:45,772 DEBUG MQTT Publishing: emon/emontx3cm16/P2 0
2026-11-01 14:00:45,773 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2026-11-01 14:00:45,774 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2026-11-01 14:00:45,775 DEBUG MQTT Publishing: emon/emontx3cm16/E1 385883
2026-11-01 14:00:45,777 DEBUG MQTT Publishing: emon/emontx3cm16/E2 4769
2026-11-01 14:00:45,778 DEBUG MQTT Publishing: emon/emontx3cm16/E3 4293875904
2026-11-01 14:00:45,779 DEBUG MQTT Publishing: emon/emontx3cm16/E4 3342
2026-11-01 14:00:45,781 DEBUG MQTT Publishing: emon/emontx3cm16/T1 300
2026-11-01 14:00:45,782 DEBUG MQTT Publishing: emon/emontx3cm16/T2 300
2026-11-01 14:00:45,783 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2026-11-01 14:00:45,784 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 15
2026-11-01 14:00:45,785 DEBUG MQTT Publishing: emon/emontx3cm16/missed 1872
2026-11-01 14:00:45,786 DEBUG MQTT Publishing: emon/emontx3cm16/missedprc 3.011001737116387
2026-11-01 14:00:45,787 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -29
2026-11-01 14:00:45,788 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:45,789 DEBUG MQTT Publishing: emonhub/rx/16/values 309942,226.58,939,0,0,0,385883,4769,4293875904,3342,300,300,300,15,1872,3.011001737116387,-29
2026-11-01 14:00:47,082 DEBUG RFM2Pi 251909 NEW FRAME : OK 5 40 64 61 0 101 64 248 86 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2026-11-01 14:00:47,084 DEBUG RFM2Pi 251909 Timestamp : 1793541647.082297
2026-11-01 14:00:47,084 DEBUG RFM2Pi 251909 From Node : 5
2026-11-01 14:00:47,085 DEBUG RFM2Pi 251909 Values : [16424, 61, 16485, 222.64000000000001, 0, 0, 0, 0, 0, 0, 0]
2026-11-01 14:00:47,085 DEBUG RFM2Pi 251909 Sent to channel(start)' : ToEmonCMS
2026-11-01 14:00:47,086 DEBUG RFM2Pi 251909 Sent to channel(end)' : ToEmonCMS
2026-11-01 14:00:47,104 DEBUG MQTT Publishing: emon/emonpi/power1 16424
2026-11-01 14:00:47,105 DEBUG MQTT Publishing: emon/emonpi/power2 61
2026-11-01 14:00:47,106 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 16485
2026-11-01 14:00:47,107 DEBUG MQTT Publishing: emon/emonpi/vrms 222.64000000000001
2026-11-01 14:00:47,108 DEBUG MQTT Publishing: emon/emonpi/t1 0
2026-11-01 14:00:47,109 DEBUG MQTT Publishing: emon/emonpi/t2 0
2026-11-01 14:00:47,110 DEBUG MQTT Publishing: emon/emonpi/t3 0
2026-11-01 14:00:47,111 DEBUG MQTT Publishing: emon/emonpi/t4 0
2026-11-01 14:00:47,112 DEBUG MQTT Publishing: emon/emonpi/t5 0
2026-11-01 14:00:47,113 DEBUG MQTT Publishing: emon/emonpi/t6 0
2026-11-01 14:00:47,114 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2026-11-01 14:00:47,115 INFO MQTT Publishing 'node' formatted msg
2026-11-01 14:00:47,115 DEBUG MQTT Publishing: emonhub/rx/5/values 16424,61,16485,222.64000000000001,0,0,0,0,0,0,0
I’m not sure if I am reading the logs right, but it looks like emonHub is publishing the data to MQTT, but it doesn’t seem to be making it’s way to the inputs.
Could this be an issue in MQTT?
