Look where the voltage measurement is in Fig 3a. Each 120 V load gets ½V, the 240 V load gets all of V.
P = V × I.
The power in the ‘top’ 120 V load is ½V × I1
The power in the ‘bottom’ 120 V load is ½V × I2
The power in the 240 V load is V × I3
Is that clear so far?
Add them together:
Total Power = ½V × I1 + ½V × I2 + V × I3
Now here’s the really tricky part – you need to recognise that you can write:
V × I3 = ½V × I3 + ½V × I3
So substitute that into the total power:
Total Power = ½V × I1 + ½V × I2 + ½V × I3 + ½V × I3
Now collect up the parts with ‘Ix’ in that make up ICT1 and ICT2
Total Power = (½V × I1 + ½V × I3) + (½V × I2 + ½V × I3)
and put the common terms outside the brackets:
Total Power = ½V × (I1 + I3) + ½V × (I2 + I3)
and those terms inside the brackets are ICT1 and ICT2, are they not?
That’s all very, very basic algebra - the stuff I learned about 60 years ago in school. If that doesn’t help, I’m at a loss to know what your problem is.
