# Node values missing
**URL:** <https://community.openenergymonitor.org/t/node-values-missing/3471>\
**Category:** Emoncms\
**Created:** [19 March 2017 08:04 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471 "2017-03-19T08:04:45Z")\
**Posts on this page:** 5\
**Author:** ![bphermansson](https://community.openenergymonitor.org/letter_avatar_proxy/v4/letter/b/ac91a4/32.png) [@bphermansson](https://community.openenergymonitor.org/u/bphermansson)\
**Post date:** [19 March 2017 08:04 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471/1 "2017-03-19T08:04:45Z")
I have a custom transmitter that sends values to a local Emoncms installation. It has node number 27. In emonhub.log I see this:
```auto
                                                19042 From Node : 27
    2017-03-01 16:01:16,609 DEBUG RFM2Pi 19042 Values : [3305, 986.147216796875, 24.0257568359375, 1, 30, 0.2490234375, 31.264968872070312]
    2017-03-01 16:01:16,619 DEBUG RFM2Pi 19042 RSSI : -62
    2017-03-01 16:01:16,640 INFO RFM2Pi Publishing: emon/emonTXv2/batteryvolt 3305
    2017-03-01 16:01:16,656 INFO RFM2Pi Publishing: emon/emonTXv2/pres 986.147216797
    2017-03-01 16:01:16,674 INFO RFM2Pi Publishing: emon/emonTXv2/bmptemp 24.0257568359
    2017-03-01 16:01:16,689 INFO RFM2Pi Publishing: emon/emonTXv2/uvraw 1
    2017-03-01 16:01:16,726 INFO RFM2Pi Publishing: emon/emonTXv2/humidity 30
    2017-03-01 16:01:16,762 INFO RFM2Pi Publishing: emon/emonTXv2/solarV 0.2490234375
    2017-03-01 16:01:16,775 INFO RFM2Pi Publishing: emon/emonTXv2/power 31.2649688721
    2017-03-01 16:01:16,788 INFO RFM2Pi Publishing: emon/emonTXv2/rssi -62
    2017-03-01 16:01:16,800 INFO RFM2Pi Publishing: emonhub/rx/27/values 3305,986.147216797,24.0257568359,1,30,0.2490234375,31.2649688721
    2017-03-01 16:01:16,826 INFO RFM2Pi Publishing: emonhub/rx/27/rssi -62
    2017-03-01 16:01:16,871 DEBUG RFM2Pi 19042 adding frame to buffer => [1488380476, 27, 3305, 986.147216796875, 24.0257568359375, 1, 30, 0.2490234375, 31.264968872070312, -62]
Here I see my seven values plus rssi as expected.
Then I go to Setup/Inputs and only see this:
emonTXv2 rssi 4 mins -62
In my config I have this:
```auto
[[27]]
    nodename = emonTXv2
    [[[rx]]]
       names = batteryvolt, pres, bmptemp, uvraw, humidity, solarV, power
       datacodes = h,f,f,h,h,f,f
       scales = 1,1,1,1,1,1,1
       units = V,hPa,C,%,%,V,W
Why doesn’t all values show up as inputs?
**Author:** ![pb66](https://community.openenergymonitor.org/user_avatar/community.openenergymonitor.org/pb66/32/27_2.png) [@pb66](https://community.openenergymonitor.org/u/pb66)\
**Post date:** [19 March 2017 09:57 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471/2 "2017-03-19T09:57:56Z")
See the [“Newly created inputs not appearing in emonCMS via MQTT”](https://community.openenergymonitor.org/t/newly-created-inputs-not-appearing-in-emoncms-via-mqtt/2515) thread for more details, but it is a known bug with emoncms’s MQTT interface that has not yet been addressed.
Rebooting the emonPi should make the inputs appears.
**Post date:** [23 March 2017 05:20 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471/3 "2017-03-23T05:20:10Z")
Thanks. But that doesnt work.
I try to upgrade my installation now following [emoncms/Upgrading.md at master · emoncms/emoncms · GitHub](https://github.com/emoncms/emoncms/blob/master/docs/Upgrading.md).
But I don’t find where Apache redirects. If I open my Raspbians Ip in the browser (192.168.1.79) I get redirected to [http://192.168.1.79/emoncms/](http://192.168.1.79/emoncms/). But where does this happen? Dont see any virtual host in /etc/apache2/sites-enabled/000-default.conf?
**Post date:** [8 April 2017 04:41 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471/4 "2017-04-08T04:41:42Z")
Ok I found the redirect in an index file in /var/www.
But the problem is still there, I dont see all my inputs. Rebooting the Pi didn’t help.
What more to try?
**Post date:** [16 April 2017 10:47 UTC](https://community.openenergymonitor.org/t/node-values-missing/3471/5 "2017-04-16T10:47:57Z")
No ideas?
