Hi, I ave just built an openevse kit which works but I can not get the WiFi module to work. It’s getting power and if I reset the WiFi units lights blink, but I can not get it to show a WiFi network. I’m guessing the module could be faulty? Any help please.
Good work getting the OpenEVSE up and running. The WiFi module can be tested seperatly if required. When powered up the WiFi module should broadcast an access point called “Open_EVSExxx”. To check the module as power the blue light on the module should flash quickly at startup and flash if the RST button on the module is pressed.
If it does not do this then the module must be faulty. We will send you a replacement
