I’ve configured EmonPi as described here Solar PV - Guide | OpenEnergyMonitor
The problem is that no data are coming to my feeds
What should I check ?
What does the input page look like?
I’ve just discovered that at the end of the long input page I’ve this
Was my fault because when I followed the guide I did not select the gear next to “emonpi”. My bad. Maybe a note in the doc highlighting the fact that the “emonpi” section is at the end could help.
So you just need to connect these inputs to the feeds.
[edit]
BTW should Power 1 be negative? if not turn the CT round.
