Alright, I’m back to where I was before. There was no corruption. I did have to:
mkdir /var/lib/phpfina
chown www-data:www-data !$
emonhub is getting samples and sending them to emoncms as above. emoncms found an input. I created a feed from said input but nothing is showing up on the graph as though the data is not being kept.
The last 3 samples from my emonhub.log:
2019-10-31 11:25:36,978 DEBUG Serial 157 NEW FRAME : ct1:96,ct2:0,ct3:0,ct4:0,vrms:11374,pulse:0
2019-10-31 11:25:36,980 DEBUG Serial 157 Timestamp : 1572521136.98
2019-10-31 11:25:36,982 DEBUG Serial 157 From Node : 0
2019-10-31 11:25:36,983 DEBUG Serial 157 Values : [96, 0, 0, 0, 11374, 0]
2019-10-31 11:25:36,984 DEBUG Serial 157 Sent to channel(start)' : ToEmonCMS
2019-10-31 11:25:36,985 DEBUG Serial 157 Sent to channel(end)' : ToEmonCMS
2019-10-31 11:25:37,082 DEBUG MQTT Publishing: emon/0/ct1 96
2019-10-31 11:25:37,084 DEBUG MQTT Publishing: emon/0/ct2 0
2019-10-31 11:25:37,086 DEBUG MQTT Publishing: emon/0/ct3 0
2019-10-31 11:25:37,089 DEBUG MQTT Publishing: emon/0/ct4 0
2019-10-31 11:25:37,091 DEBUG MQTT Publishing: emon/0/vrms 11374
2019-10-31 11:25:37,093 DEBUG MQTT Publishing: emon/0/pulse 0
2019-10-31 11:25:37,095 INFO MQTT Publishing: emonhub/rx/0/values 96,0,0,0,11374,0
2019-10-31 11:25:46,894 DEBUG Serial 158 NEW FRAME : ct1:96,ct2:0,ct3:0,ct4:0,vrms:11378,pulse:0
2019-10-31 11:25:46,895 DEBUG Serial 158 Timestamp : 1572521146.89
2019-10-31 11:25:46,896 DEBUG Serial 158 From Node : 0
2019-10-31 11:25:46,896 DEBUG Serial 158 Values : [96, 0, 0, 0, 11378, 0]
2019-10-31 11:25:46,897 DEBUG Serial 158 Sent to channel(start)' : ToEmonCMS
2019-10-31 11:25:46,898 DEBUG Serial 158 Sent to channel(end)' : ToEmonCMS
2019-10-31 11:25:47,193 DEBUG MQTT Publishing: emon/0/ct1 96
2019-10-31 11:25:47,195 DEBUG MQTT Publishing: emon/0/ct2 0
2019-10-31 11:25:47,197 DEBUG MQTT Publishing: emon/0/ct3 0
2019-10-31 11:25:47,199 DEBUG MQTT Publishing: emon/0/ct4 0
2019-10-31 11:25:47,201 DEBUG MQTT Publishing: emon/0/vrms 11378
2019-10-31 11:25:47,203 DEBUG MQTT Publishing: emon/0/pulse 0
2019-10-31 11:25:47,205 INFO MQTT Publishing: emonhub/rx/0/values 96,0,0,0,11378,0
2019-10-31 11:25:54,587 DEBUG emoncmsorg Buffer size: 3
2019-10-31 11:25:56,788 DEBUG Serial 159 NEW FRAME : ct1:97,ct2:0,ct3:0,ct4:0,vrms:11374,pulse:0
2019-10-31 11:25:56,789 DEBUG Serial 159 Timestamp : 1572521156.79
2019-10-31 11:25:56,790 DEBUG Serial 159 From Node : 0
2019-10-31 11:25:56,791 DEBUG Serial 159 Values : [97, 0, 0, 0, 11374, 0]
2019-10-31 11:25:56,792 DEBUG Serial 159 Sent to channel(start)' : ToEmonCMS
2019-10-31 11:25:56,793 DEBUG Serial 159 Sent to channel(end)' : ToEmonCMS
2019-10-31 11:25:56,884 DEBUG MQTT Publishing: emon/0/ct1 97
2019-10-31 11:25:56,887 DEBUG MQTT Publishing: emon/0/ct2 0
2019-10-31 11:25:56,889 DEBUG MQTT Publishing: emon/0/ct3 0
2019-10-31 11:25:56,891 DEBUG MQTT Publishing: emon/0/ct4 0
2019-10-31 11:25:56,894 DEBUG MQTT Publishing: emon/0/vrms 11374
2019-10-31 11:25:56,896 DEBUG MQTT Publishing: emon/0/pulse 0
2019-10-31 11:25:56,899 INFO MQTT Publishing: emonhub/rx/0/values 97,0,0,0,11374,0
