Hello I’ve set-up the emoncms application on my Andriod phone and it works well at home. However when I’m not on my home network I get CONNECTION ERROR in the app. I thought the idea of the apps was for internet use, so I assume I’ve set something wrong.
It may be relevant, but on emoncms.org/feeds they all show as inactive.
Can you view emoncms from a normal browser when away from home?
That sounds like you are using a local IP address on your LAN to access the emoncms instance, that route/address is only valid when connected to your home LAN. It will not work over a mobile data network.
It is. But it uses an existing route, it doesn’t provide a new route. So it will only work if you can already see your emoncms instance whilst away from the house. It is only a mobile friendly viewer application.
To make emoncms accessible from outside your LAN you need to either
set up port forwarding and probably an account with a dynamic dns provider or
Hi Paul, thanks for your help. My mistake was thinking emonpi was local and emoncms was external. I’ve now resolved the issue. I repeated setting up the inputs and feeds I used on emoncms, but did it on emoncms.org internet account. I’ll admit it was a bit of trial and error getting it to work, but it now looks correct.
