Hi There - I’ve had my emon setup for a few weeks but was waiting on the AC-AC adapter to come in to ask any questions. I took the system down this morning to install the adapter, which is when the graph changes. Previously the daytime consumption while solar was producing had the consumption/export swapped.
I am running the new emonPi (plastic back). Not sure if there are any other version info points I should add?
I have got it plugged in now and the addition of the AC-AC seems to have dropped the solar to 0W and is giving me a negative consumption info. The values in the feed section seem to be correct, but they aren’t translating into the MySolar app.
In the example below, my solar production should be the -2180 (matches my inverter reading), the export should be the 1815, and the consumption the difference 365. When I go to the MySolar app the solar is coming up as 0W and the consumption -365W.
I assume I’m doing something noobish, but can’t figure out what is going on. Would be great to get some input / assistance.
