chivakaa
(Dan)
14 December 2019 12:25
#1
Ok,
Thank you Borpin, I have exported all Emoncms data of old SD card (following backup procedure) and I have performed a fresh installation of emoncms on a new SD card
Now app and services are running as expected. But I have just one issue after do the process. My system has emonPi + emonTx V3 and EmonTx does not report any input… I have not clear what is the process to restart it or reconfigure, any clue?
Thanks for everyone for your support!
borpin
(Brian Orpin)
14 December 2019 12:38
#2
Hi @chivakaa .
Can I confirm that the Input is not appearing on the ‘Inputs’ page?
Can you post the emonhub log and config please. Easiest is to attach the files. I have bumped your trust level so that should be OK.
Than you Borpin,
Sorry for later response, Xmas, two children… anyway following all details.
Under inputs page, emonpi works fine but EmonTX v3 does not show any value (attached view).
Also, attached config file and logs file
Config file: /opt/openenergymonitor/emonhub/conf/emonhub.conf
Log file: /var/log/emoncms/emoncms.log
Upss not authorized upload files (emonhub.conf & emoncms.log), error:
Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, zip, tar, ino, ico, txt, pdf, sch, brd, odt, gz, mp4, mov, ods, csv, doc, webm, bin, hex).
Hello @chivakaa could you copy here /var/log/emonhub/emonhub.log, try renaming as .txt for upload.
borpin
(Brian Orpin)
7 January 2020 17:23
#5
I’m wondering why there is no emonhub entry (nor Wi-Fi) on the left menu. Looks like a bad install/flash.
Can you click on the button Copy as Markdown next to Server Information on the Admin page and paste here please (no further formatting required ).
Thank you @TrystanLea & @borpin
Renamed both files to .txt and attached.
emoncms.txt (2.4 MB)
emonhub.conf.txt (7.5 KB)
Regarding Wi-Fi interface, yes you are in right that is not present on emoncms menu, but interface is up and running (configured by Network Manager Text User Interface (NMTUI)).
Wired interface works with static configuration and Wi-Fi with DHCP. Both are connected and listening on TCP 22.
Following information details provided from Copy as Markdown button
Server Information
Server Information
Services
emonhub :- Active Running
emoncms_mqtt :- Active Running
feedwriter :- Active Running - sleep 300s 259 feed points pending write
service-runner :- Active Running
emonPiLCD :- Active Running
redis-server :- Active Running
mosquitto :- Active Running
demandshaper :- Active Running
Emoncms
Version :- low-write 10.1.13
Modules :- Administration | App v2.0.9 | Backup v2.1.7 | Dashboard v2.0.5 | DemandShaper v1.1.0 | Device v2.0.3 | EventProcesses | Feed | Graph v2.0.7 | Input | Postprocess v2.1.2 | CoreProcess | Schedule | sync | Time | User | Visualisation
Git :-
Server
OS :- Linux 4.19.86-v7+
Host :- emonpi | emonpi | (192.168.1.22)
Date :- 2020-01-12 11:06:59 CET
Uptime :- 11:06:59 up 5 days, 4 min, 3 users, load average: 1.00, 0.83, 0.80
Memory
RAM :- Used: 32.57%
Total :- 975.61 MB
Used :- 317.77 MB
Free :- 657.84 MB
Swap :- Used: 3.50%
Total :- 100 MB
Used :- 3.5 MB
Free :- 96.5 MB
Write Load Period
Disk
/ :- Used: 19.42%
Total :- 23.4 GB
Used :- 4.55 GB
Free :- 17.86 GB
Write Load :- 3.92 KB/s (0 mins)
/repo :- Used: 35.47%
Total :- 8.67 GB
Used :- 3.07 GB
Free :- 5.13 GB
Write Load :- n/a
/usr/local :- Used: 8.70%
Total :- 975.9 MB
Used :- 84.87 MB
Free :- 823.83 MB
Write Load :- n/a
/var/opt/emoncms :- Used: 0.05%
Total :- 8.06 GB
Used :- 3.77 MB
Free :- 7.65 GB
Write Load :- 0 B/s (0 mins)
/boot :- Used: 20.69%
Total :- 252.05 MB
Used :- 52.14 MB
Free :- 199.91 MB
/var/log :- Used: 100.00%
Total :- 50 MB
Used :- 50 MB
Free :- 0 B
Write Load :- n/a
HTTP
Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
Host :- localhost:6379 (127.0.0.1)
Date :- 2020-01-12 11:06:59 (UTC 01:00)
Stats :- Uptime: 432269 Threads: 14 Questions: 3865960 Slow queries: 0 Opens: 49 Flush tables: 1 Open tables: 43 Queries per second avg: 8.943
Redis
Version :-
Redis Server :- 5.0.3
PHP Redis :- 5.1.1
Size :- 157 keys (859.77K)
Uptime :- 5 days
MQTT Server
Version :- Mosquitto 1.5.7
Host :- localhost:1883 (127.0.0.1)
PHP
Version :- 7.3.11-1~deb10u1 (Zend Version 3.3.11)
Modules :- apache2handler | calendar v7.3.11-1~deb10u1 | Core v7.3.11-1~deb10u1 | ctype v7.3.11-1~deb10u1 | curl v7.3.11-1~deb10u1 | date v7.3.11-1~deb10u1 | dom v20031129 | exif v7.3.11-1~deb10u1 | fileinfo v7.3.11-1~deb10u1 | filter v7.3.11-1~deb10u1 | ftp v7.3.11-1~deb10u1 | gd v7.3.11-1~deb10u1 | gettext v7.3.11-1~deb10u1 | hash v7.3.11-1~deb10u1 | iconv v7.3.11-1~deb10u1 | json v1.7.0 | libxml v7.3.11-1~deb10u1 | mbstring v7.3.11-1~deb10u1 | mosquitto v0.4.0 | mysqli v7.3.11-1~deb10u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $ | openssl v7.3.11-1~deb10u1 | pcre v7.3.11-1~deb10u1 | PDO v7.3.11-1~deb10u1 | pdo_mysql v7.3.11-1~deb10u1 | Phar v7.3.11-1~deb10u1 | posix v7.3.11-1~deb10u1 | readline v7.3.11-1~deb10u1 | redis v5.1.1 | Reflection v7.3.11-1~deb10u1 | session v7.3.11-1~deb10u1 | shmop v7.3.11-1~deb10u1 | SimpleXML v7.3.11-1~deb10u1 | sockets v7.3.11-1~deb10u1 | sodium v7.3.11-1~deb10u1 | SPL v7.3.11-1~deb10u1 | standard v7.3.11-1~deb10u1 | sysvmsg v7.3.11-1~deb10u1 | sysvsem v7.3.11-1~deb10u1 | sysvshm v7.3.11-1~deb10u1 | tokenizer v7.3.11-1~deb10u1 | wddx v7.3.11-1~deb10u1 | xml v7.3.11-1~deb10u1 | xmlreader v7.3.11-1~deb10u1 | xmlwriter v7.3.11-1~deb10u1 | xsl v7.3.11-1~deb10u1 | Zend OPcache v7.3.11-1~deb10u1 | zlib v7.3.11-1~deb10u1
Pi
Model :- Raspberry Pi 3 Model B Rev 1.2 - 1GB (Sony UK)
Serial num. :- 4E0CF92A
Temperature :- 49.93°C - 50.5°C
emonpiRelease :- emonSD-02Oct19
File-system :- read-write
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.4 Safari/605.1.15
Language :- en-gb
Window
Screen
Resolution :- 1792 x 1120
Thanks for you comments.
borpin
(Brian Orpin)
12 January 2020 14:34
#7
My point is, it should be present if you used a new Image. It suggests the new image did not initialise correctly especially as the emonhub menu item is missing as well.
The fact that something is not right, suggests to me there may be deeper problems with the setup. The module list should look like this on a standard Image.
I think you will be better off trying a new base image again. It is not unheard of for the initialisation to fail - usually because the device is rebooted before the updates have completed.
Thanks @chivakaa , looks like your emonSD release is emonSD-02Oct19 which is strange, it should be emonSD-17Oct19, I’d suggest starting again with a new download of the 17th of October image:
emonSD pre built SD card Download & Change Log · openenergymonitor/emonpi Wiki · GitHub
