@TrystanLea as now confirmed this isn’t working as expected so to have non-timestamped payload delete or comment out the timestamped value altogether as any value there True,true,False,false will require a timestamp, this is a bug and I will take a look once i get a emonpi set up again.
[edit - Issue raised so it doesn’t get forgotten ]
I think you mean (timestamp 98 6.8 6.2 8.6 77.0), had you sent a timestamp I would have worked, albeit with a timestamp. However just knowing the position of the “6.8” in the payload would have helped, Trystan has now tried this and confirmed the situation so I don’t need the log entries now.
For now comment out or delete the timestamped = line for non-timestamped data.
@TrystanLea has also confirmed data getting to emoncms so hopefully it should all work for you once you define the channel(s).
I’ve fixed the timestamp property bug and updated the emonhub configuration documentation with an example of how to use the socket interfacer, thanks @pb66 I can see how useful this interfacer could be now:
