Hello,
I have a emonpi installation which is used to log power, vrms and temperature to local emoncms and emoncms.org. I am using also 2 emonth’s for temperature and humidity, also logging local and emoncms.org. Everything works ok.
I recently added another node in my emonpi config - node 99 - for some temperature, humidity and voltage data from a remote device. The data is pulled form the remote device using a python script which send the data to my local emoncms.
The configuration added to my emonhub.conf is:
[[99]]
nodename = lan_restarter
[[[rx]]]
names = temp1, ext temp, temp2, temp0, int temp,humidity,vcc
datacodes = h,h,h,h,h,h,h
scales = 0.1,0.1,0.1,0.1,0.1,0.1,0.1
units = C,C,C,C,C,%,V
I see the inputs for node 99 in my local emoncms, I configured them to Log to feed - everything is fine with the local emoncms.
My issue is that I cannot see the data regarding node 99 in emoncms.org. All the other data from emonpi and the 2 emonth are sent successful to emoncms.org:
2018-01-29 08:42:11,347 DEBUG RFM2Pi 15991 NEW FRAME : OK 23 223 0 55 0 71 1 15 0 1 0 0 0 (-50)
2018-01-29 08:42:11,350 DEBUG RFM2Pi 15991 Timestamp : 1517215331.35
2018-01-29 08:42:11,351 DEBUG RFM2Pi 15991 From Node : 23
2018-01-29 08:42:11,352 DEBUG RFM2Pi 15991 Values : [22.3, 5.5, 32.7, 1.5, 1]
2018-01-29 08:42:11,352 DEBUG RFM2Pi 15991 RSSI : -50
2018-01-29 08:42:11,353 DEBUG RFM2Pi 15991 Sent to channel(start)' : ToEmonCMS
2018-01-29 08:42:11,354 DEBUG RFM2Pi 15991 Sent to channel(end)' : ToEmonCMS
2018-01-29 08:42:11,547 DEBUG MQTT Publishing: emon/emonth5/temperature 22.3
2018-01-29 08:42:11,549 DEBUG MQTT Publishing: emon/emonth5/external temperature 5.5
2018-01-29 08:42:11,550 DEBUG MQTT Publishing: emon/emonth5/humidity 32.7
2018-01-29 08:42:11,552 DEBUG MQTT Publishing: emon/emonth5/battery 1.5
2018-01-29 08:42:11,554 DEBUG MQTT Publishing: emon/emonth5/pulsecount 1
2018-01-29 08:42:11,555 INFO MQTT Publishing: emon/emonth5/rssi -50
2018-01-29 08:42:11,557 INFO MQTT Publishing: emonhub/rx/23/values 22.3,5.5,32.7,1.5,1
2018-01-29 08:42:11,558 INFO MQTT Publishing: emonhub/rx/23/rssi -50
2018-01-29 08:42:11,984 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 34 0 55 0 71 1 15 0 1 0 0 0 39 163 0 32 32 0 32 0 (-106)
2018-01-29 08:42:28,725 DEBUG MQTT Publishing: emon/emonpi/power1 737
2018-01-29 08:42:28,727 DEBUG MQTT Publishing: emon/emonpi/power2 0
2018-01-29 08:42:28,728 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 737
2018-01-29 08:42:28,730 DEBUG MQTT Publishing: emon/emonpi/vrms 219.77
2018-01-29 08:42:28,731 DEBUG MQTT Publishing: emon/emonpi/t1 24.3
2018-01-29 08:42:28,733 DEBUG MQTT Publishing: emon/emonpi/t2 0
2018-01-29 08:42:28,735 DEBUG MQTT Publishing: emon/emonpi/t3 0
2018-01-29 08:42:28,736 DEBUG MQTT Publishing: emon/emonpi/t4 0
2018-01-29 08:42:28,738 DEBUG MQTT Publishing: emon/emonpi/t5 0
2018-01-29 08:42:28,739 DEBUG MQTT Publishing: emon/emonpi/t6 0
2018-01-29 08:42:28,741 DEBUG MQTT Publishing: emon/emonpi/pulsecount 0
2018-01-29 08:42:28,742 INFO MQTT Publishing: emon/emonpi/rssi 0
2018-01-29 08:42:28,744 INFO MQTT Publishing: emonhub/rx/5/values 737,0,737,219.77,24.3,0,0,0,0,0,0
2018-01-29 08:42:28,745 INFO MQTT Publishing: emonhub/rx/5/rssi 0
2018-01-29 08:42:28,809 DEBUG RFM2Pi 15996 NEW FRAME : OK 24 240 0 0 0 41 1 28 0 1 0 0 0 (-63)
2018-01-29 08:42:28,811 DEBUG RFM2Pi 15996 Timestamp : 1517215348.81
2018-01-29 08:42:28,812 DEBUG RFM2Pi 15996 From Node : 24
2018-01-29 08:42:28,813 DEBUG RFM2Pi 15996 Values : [24, 0, 29.700000000000003, 2.8000000000000003, 1]
2018-01-29 08:42:28,815 DEBUG RFM2Pi 15996 RSSI : -63
2018-01-29 08:42:28,815 DEBUG RFM2Pi 15996 Sent to channel(start)' : ToEmonCMS
2018-01-29 08:42:28,819 DEBUG RFM2Pi 15996 Sent to channel(end)' : ToEmonCMS
2018-01-29 08:42:28,964 DEBUG MQTT Publishing: emon/emonth6/temperature 24
2018-01-29 08:42:28,965 DEBUG MQTT Publishing: emon/emonth6/external temperature 0
2018-01-29 08:42:28,966 DEBUG MQTT Publishing: emon/emonth6/humidity 29.7
2018-01-29 08:42:28,967 DEBUG MQTT Publishing: emon/emonth6/battery 2.8
2018-01-29 08:42:28,967 DEBUG MQTT Publishing: emon/emonth6/pulsecount 1
2018-01-29 08:42:28,968 INFO MQTT Publishing: emon/emonth6/rssi -63
2018-01-29 08:42:28,969 INFO MQTT Publishing: emonhub/rx/24/values 24,0,29.7,2.8,1
2018-01-29 08:42:28,970 INFO MQTT Publishing: emonhub/rx/24/rssi -63
2018-01-29 08:42:32,405 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 0 0 34 32 0 0 0 32 32 0 32 0 32 0 0 0 0 32 0 32 (-106)
2018-01-29 08:42:33,540 DEBUG RFM2Pi 15997 NEW FRAME : OK 5 233 2 0 0 233 2 208 85 243 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2018-01-29 08:42:36,921 DEBUG emoncmsorg Sending bulkdata, length: 8
2018-01-29 08:42:36,923 INFO emoncmsorg sending: https://emoncms.org/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1517215328.45389,5,751,0,751,220.26,24.3,0,0,0,0,0,0],[1517215331.34766,23,22.3,5.5,32.7,1.5,1,-50],[1517215333.519791,5,758,0,758,219.77,24.3,0,0,0,0,0,0],[1517215338.478148,5,769,0,769,220.04,24.3,0,0,0,0,0,0],[1517215343.463304,5,738,0,738,220.11,24.3,0,0,0,0,0,0],[1517215348.485342,5,737,0,737,219.77,24.3,0,0,0,0,0,0],[1517215348.808746,24,24,0,29.700000000000003,2.8000000000000003,1,-63],[1517215353.540321,5,745,0,745,219.68,24.3,0,0,0,0,0,0]]&sentat=1517215356
2018-01-29 08:42:37,309 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 32 0 34 32 0 0 0 32 32 0 32 0 32 0 0 0 0 32 0 32 (-103)
2018-01-29 08:42:37,387 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
2018-01-29 08:42:37,387 DEBUG emoncmsorg Sending bulkdata, success: True
2018-01-29 08:42:37,389 DEBUG emoncmsorg Current queue length: 0
2018-01-29 08:42:37,390 INFO emoncmsorg sending: https://emoncms.org/myip/set.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
What am I missing?
