Hi Brian
yes you should set redis_enabled = true to get the full suite of processing options. I cannot think of any good reason not to use it if it is installed, that is the deciding factor, can I install it? that setting is there, if required to tell emoncms not to use Redis, usually because it can’t be installed (windows or shared hosting without root access)
