I am trying the new interface to create feeds and have a number of comments.
The input from which I am creating the feed looks like this
and I’d like to end up with a feed grouped like this (at the bottom is how a feed is created).
When trying to add a feed, although I can see the ones I already have, I only have one box in which to create the node/feed name. It should be possible to create the right node & name combination from here.
The confusion is compounded when I come to edit the feed name as it presents me with a different naming convention and in the wrong order.
The ‘Node’ is the group, so logically should be first. It would be useful if is presented you with a dropdown of existing Node names (prevents misspelling) and the option to add a new Node.
