Hello,
Finally my EmonTX v2 shield arrived. After reading more carefully the specifications it says that EmonTx is not compatible with other I2C shields. My plan is to use emon library and EmonTx (with included voltage monitor) for the actual energy monitoring but after that send the data to my Domoticz home automation. However, all my nodes and the main hub are now using either NRF24L01 or ESP8266 for communication and therefore I cannot use RFM69. So the question is that does the “not compatible with other I2C shields” apply anymore? Could I just leave the RFM69 unsoldered and hook up my NRF24 radio on it?
