I cannot seem to select my feeds as input to this app. I have a Power Feed and a KWh feed I cannot select them in the drop down lists to use for the app.
Is there a way to use my own feeds in these apps?
Cheers
Tony.
Cheers
Tony.
What feeds are you trying to select? Are they phpfina (fixed interval) feeds? Without hacking, the app module only works with phpfina feeds.
Otherwise, do they have any odd characters in the name?
They were not fixed time feeds whilst I am testing. Will test some more with fixed time feeds and setup the scheduler to grab the info.
Cheers
Tony
Added the two PHPFINA feeds and now its working. Thank you for your help.
Cheers
Tony
