I log now since 2,5 days and I see that the History infos are not the same as the power view:
When I click “show History”, I has to bars.
With mouse over he show me the values at the bottom:
use, solar, direct, export, grid
but when I click on this bar, the power view is opening and direct, export and grid are different.
use and solar are correct … but sometimes I see a different of 0,1 kWh.
Is this normal?
In my unterstood, the bargraph show the daily data.
So from 0:00 - 23:59
Thanks. Ah, I see. It looks like this could be to do with how the figures are calculated, real-time vs accumulator data. @TrystanLea wrote the MySolar module, I will ask him to take a look.
I checked the console when I open “mysolarpv”.
When I´m not logged in, I get:
app2.js:175 ERROR: feed.getmeta invalid response: false
But when I´m logged in, I have not this errors.
It seems coming from thr kwh feeds.
Also the variable app_mysolarpv.latest_start_time is 0, when I´m not logged in.
Thanks for letting us know, you have found a bug. This has now been fixed by @TrystanLea :
Fix has been pushed to stable branch. Please update your emonPi using update emonPi button in the admin interface and confirm issue has been fixed. Thanks.
