An update to this ageing thread. The issue continued exactly as before, often freezing and needing to be restarted. In fact, I added a smartplug to the 5v supply so I can remote power cycle it, because the issue happened so often.
This did not used to happen and so we all looked at issue around the age of the EmonTx board etc, but it also did not used to have four CTs plugged in so I am thinking more about that now. Could a timing issue in an older EmonTx firmware cause it to freeze?
Since getting a UART adapter, I have updated both the EmonTx and EmonESP firmware to versions 3.3.0 and 3.0.0 respectively. The continuous monitoring version of the EmonTx firmware did not seem to be compatible with EmonESP, unless I’m missing something.
In the past week, this has been stable. I will report back further after a longer test period.
