Hello all. I am a newbie with this system. Just took it out of the box and installed yesterday. Earlier today Brian helped me out with my temp. probe so that issue is solved. I am now trying to set up My Electric App on home PC. I have all good inputs and have created the following feeds to monitor:
Total Home Power Usage (kWhr)
Split phase A (Watts)
Split phase B (Watts)
Outdoor temperature in deg C
Total Real Time Home Power Usage (Watts)
The feeds above are all active and appear to be working properly.
I selected the My Electric App, which I set up and started. On start up I got the following message:
Emoncms Error
Message: Uncaught TypeError: Cannot read property ‘0’ of undefined
Route: Modules/app/Lib/time series.js?v=8
Corresponding admin Emoncms log wrote the following:
2019-11-19 17:06:43.114|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-19 17:06:43.285|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-19 17:53:44.572|WARN|index.php|406 Not Acceptable|Modules/app/Views
2019-11-19 17:53:44.648|WARN|index.php|406 Not Acceptable|Modules/app/Views
2019-11-19 18:05:12.137|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
2019-11-19 18:06:22.419|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
2019-11-19 18:37:53.286|WARN|index.php|406 Not Acceptable|Modules/app/Views
2019-11-19 18:37:53.360|WARN|index.php|406 Not Acceptable|Modules/app/Views
2019-11-19 18:39:34.210|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
2019-11-19 18:42:31.468|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
It subsequently started running however I only have “Power New” and “Cost per hr” selections (top left of app dashboard) with 0 being displayed on the right hand side (today). There are no other selections available. Is the error above why I am not getting all the feeds into the dashboard?
