I’ve got a separate PI receiving and processing telegrams from multiple water meters (it uses wmbusmeters GitHub - weetmuts/wmbusmeters: Read the wireless mbus protocol to acquire utility meter readings.). I’ve managed to get it to MQTT the data across using the following statement in the config shell=/usr/bin/mosquitto_pub -h [emoncms IP] -p 1883 -u [emon username] -P [password] -t emon -m “$METER_JSON”
Sample JSON output:
"media": "cold water",
"meter": "multical21",
"name": "MyTapWater",
"id": "12345678",
"total_m3": 6.388,
"target_m3": 6.377,
"max_flow_m3h": 0.000,
"flow_temperature": 8,
"external_temperature": 23,
"current_status": "DRY",
"time_dry": "22-31 days",
"time_reversed": "",
"time_leaking": "",
"time_bursting": "",
"timestamp": "2018-02-08T09:07:22Z",
"device": "im871a[1234567]",
"rssi_dbm": -40
The data received provides the information regarding the meter it has come from (using the example above, either name or od).
Question is… Is it possible for emonhub / emoncms to direct the data to an input / feed based on the data within it, e.g. when the JSON data contains “Meter1” as the meter id, it directs to say node 6, “Meter 2” to node 7 etc…I understand how my emonpi does it for node 5 but that is configured at source.
My emoncms (work to do) currently looks like this
