If you’re using the emonTx 3 trick of grounding the ADC input to indicate the absence of a plug, then of course you can’t share the bias supply.
If you do share the bias supply, we recommend that you provide a much lower impedance source, e.g. with an op.amp buffer providing the bias (see ‘Learn’), otherwise you are likely to get crosstalk between the various inputs.
Just explain how you’d do it any other way
