if I can help anybody with an example, I had this same isssue yesterday. Got a Tasmota Sonoff firmware (6.13) running on a esp8266 and I want to send the tempsensors DS18B20 to emoncms for recording.
this is how I did it with node-red example flow:
[{"id":"f684eeeb.842cf8","type":"emoncms","z":"75b73f52.a8a828","name":"CV Ketel","emonServer":"6b565123.62a9f8","nodegroup":"3","datatype":"legacy","x":1020,"y":1920,"wires":[]},{"id":"97360f2b.d94308","type":"mqtt in","z":"75b73f52.a8a828","name":"","topic":"tele/temp_sensor1/SENSOR/#","qos":"2","broker":"43ad90ee.18186","x":270,"y":1960,"wires":[["8ca63d65.2aac98","5e6d9035.2988"]]},{"id":"8ca63d65.2aac98","type":"debug","z":"75b73f52.a8a828","name":"tele/temp_sensor1/SENSOR","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":560,"y":1880,"wires":[]},{"id":"81edafe5.62e6a","type":"debug","z":"75b73f52.a8a828","name":"emoncms_temp_wemos","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1070,"y":2000,"wires":[]},{"id":"5e6d9035.2988","type":"json","z":"75b73f52.a8a828","name":"","pretty":false,"x":490,"y":1960,"wires":[["25d10322.bb704c"]]},{"id":"25d10322.bb704c","type":"change","z":"75b73f52.a8a828","name":"substring tasmota JSON","rules":[{"t":"move","p":"payload.DS18B20-1.Temperature","pt":"msg","to":"payload.temp1","tot":"msg"},{"t":"move","p":"payload.DS18B20-2.Temperature","pt":"msg","to":"payload.temp2","tot":"msg"},{"t":"move","p":"payload.DS18B20-3.Temperature","pt":"msg","to":"payload.temp3","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":2020,"wires":[["da1999b2.c1f058"]]},{"id":"da1999b2.c1f058","type":"function","z":"75b73f52.a8a828","name":"prepaire EmonCMS","func":"tijd = msg.payload.Time\nwarmW = msg.payload.temp1;\nketelR = msg.payload.temp2;\nketelI = msg.payload.temp3;\nmsg = {warm_water:(warmW),ketel_retour:(ketelR),ketel_aanvoer:(ketelI)};\nmytime = new Date().toISOString();\nreturn {payload:msg, time: mytime};","outputs":1,"noerr":0,"x":810,"y":1960,"wires":[["81edafe5.62e6a","f684eeeb.842cf8"]]},{"id":"6b565123.62a9f8","type":"emoncms-server","z":"","server":"http://energy.bluemotica.nl","name":""},{"id":"43ad90ee.18186","type":"mqtt-broker","z":"","name":"","broker":"mqtt.bluemotica.nl","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":false,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""}]
Input is the MQTT from the tasmota firmware, output is a emoncms input node.
I used the JSON and Switch module from node-red for converting. there is possible a nicer way but that’s my lack of skill with node-red.
