I am in the process of moving my emonTx’s over to a direct serial, is there a way of moving the input processors and logs to the new node that is created?
Failing that can I force it to change the Node 11 to emonTX_Node11?
PS I know I’ve only got three processors on node 11, but on my supply CT I’ve got 50+
If you are self-hosted you can probably rename all the “Node 11” entries to “emonTX_Node11” via the commandline or using mySQL or you should be able to copy the processlists over using the input api’s. eg get the processlist from the old input
