I’ve moved my EMONCMS to another Pi and would like to uninstall all the unused services. I need to keep the RFM69Pi running and posting to MQTT, but the rest is no longer needed.
I’ve tried to disable
apache2
feedwriter
mysql
redis
but they keep starting again after a reboot. Is there an easy way to either force this lot not to start after a reboot, or uninstall the bits I don’t need? I’ve tried
sudo update-rc.d servicename disable
and
sudo systemctl disable servicename
I think that you need to remove the services before you disable them, or use the “-f” option with update-rc.d as in sudo update-rc.d -f servicename remove, which will remove the symlinks, but not the service script (thus preventing it from running at start up).
I could be wrong, I’ve only just learned this stuff while trying to figure out my own emon problems.
Hi Nick,
thanks for the reply. Things have moved on a bit since I posted and to get rid of the problem I have uninstalled the bits I don’t need. Its good to have an explanation for what to do in future!
Cheers
Kevin
