Monitoring errors with no explanation
My system ( HeatpumpMonitor.org ), 745, is showing the icon which indicates monitoring/data errors on the system. However, when I hover over the icon I don’t get any explanation for what the problem is. That’s in contrast with other systems which have a clear explanation for at least a suspected issue.
What can I do to find out what the problem is? And ideally fix it.
I don’t know why “Data issue flag” has been set on this system without a note - maybe @glyn.hudson or @TrystanLea can shed some light on it?
I did notice that there’s no data since October 6th - you might want to check that.
Thanks Tim. I hadn’t noticed that. I think it’s sorted now - though the reason was very strange. It was claiming the API key was invalid, despite having not been changed and matching what emoncms.org was showing me. I generated a new one and set it and all was well. I have no explanation for that.
Regardless, that’s not the cause of the monitoring error on my account. That’s been around for ages, with no explanation attached.
Apologies, I’m not sure why your system was flagged. I’ve now removed the error flag.
