Hello, I am about to install a Huawei Solar PV system with 10kW battery. The inverter is a hybrid type and charges the battery with DC from the array directly. I understand all the CT clamps measure AC current so I wondered whether there is a way to monitor the DC charge current from the inverter to the battery? Thanks
It might be possible to extract the data you need directly from the inverter itself - easier if the manufacturer provides an official API. This will require writing some code to collect that data and feed it into emoncms.
Great thanks. Yes and it looks like I’ll need to request access via the installer.
cheers
