Monitor second heat meter on heatpump monitor level 3 pack?
Hello. I want to ask if there is a problem to monitor and log second mbus heatmeter on heat pump monitoring bundle level 3 if I add and addition mbus to RS485 converter and connect it to usb port?
Hi, it’s no problem to read data from a 2nd heat meter. However, the heat meter will need to be connected via MBUS to the MBUS to USB adaptor. The same MBUS adaptor can be used to read from multiple heat meters. The 2nd heat meter will need to have a different MBUS ID.
We can help set up the data logging once the 2nd meter is connected.
Please drop us an email: [email protected]
