Here is the log:
2017-04-27 15:51:40,241 DEBUG RFM2Pi 8516 NEW FRAME : OK 8 243 3 0 0 0 0 163 2 234 1 184 11 184 11 184 11 184 11 184 11 184 11 0 0 0 0 (-60)
2017-04-27 15:51:40,244 DEBUG RFM2Pi 8516 Timestamp : 1493308300.24
2017-04-27 15:51:40,245 DEBUG RFM2Pi 8516 From Node : 8
2017-04-27 15:51:40,246 DEBUG RFM2Pi 8516 Values : [1011, 0, 0, 675, 4.9, 300, 300, 300, 300, 300, 300, 0]
2017-04-27 15:51:40,246 DEBUG RFM2Pi 8516 RSSI : -60
2017-04-27 15:51:40,247 DEBUG RFM2Pi 8516 Sent to channel(start)' : ToEmonCMS
2017-04-27 15:51:40,248 INFO RFM2Pi Publishing: emon/emontx3/power1 1011
2017-04-27 15:51:40,249 INFO RFM2Pi Publishing: emon/emontx3/power2 0
2017-04-27 15:51:40,250 INFO RFM2Pi Publishing: emon/emontx3/power3 0
2017-04-27 15:51:40,251 INFO RFM2Pi Publishing: emon/emontx3/power4 675
2017-04-27 15:51:40,253 INFO RFM2Pi Publishing: emon/emontx3/vrms 4.9
2017-04-27 15:51:40,254 INFO RFM2Pi Publishing: emon/emontx3/temp1 300
2017-04-27 15:51:40,255 INFO RFM2Pi Publishing: emon/emontx3/temp2 300
2017-04-27 15:51:40,257 INFO RFM2Pi Publishing: emon/emontx3/temp3 300
2017-04-27 15:51:40,258 INFO RFM2Pi Publishing: emon/emontx3/temp4 300
2017-04-27 15:51:40,259 INFO RFM2Pi Publishing: emon/emontx3/temp5 300
2017-04-27 15:51:40,260 INFO RFM2Pi Publishing: emon/emontx3/temp6 300
2017-04-27 15:51:40,262 INFO RFM2Pi Publishing: emon/emontx3/pulse 0
2017-04-27 15:51:40,263 INFO RFM2Pi Publishing: emon/emontx3/rssi -60
2017-04-27 15:51:40,264 INFO RFM2Pi Publishing: emonhub/rx/8/values 1011,0,0,675,4.9,300,300,300,300,300,300,0
2017-04-27 15:51:40,266 INFO RFM2Pi Publishing: emonhub/rx/8/rssi -60
2017-04-27 15:51:40,267 DEBUG RFM2Pi 8516 adding frame to buffer => [1493308300.241262, 8, 1011, 0, 0, 675, 4.9, 300, 300, 300, 300, 300, 300, 0, -60]
2017-04-27 15:51:40,268 DEBUG RFM2Pi 8516 Sent to channel(end)' : ToEmonCMS
2017-04-27 15:51:41,686 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 4 140 58 199 179 (-98)
2017-04-27 15:51:42,803 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 17 50 112 60 159 132 241 25 238 101 225 8 168 247 85 253 71 73 229 190 183 (-91)
2017-04-27 15:51:44,964 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 24 7 67 211 119 156 223 207 172 79 79 146 12 4 74 49 87 249 85 16 197 (-100)
2017-04-27 15:51:45,271 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 8 169 66 7 202 113 227 27 80 116 84 72 15 173 33 142 49 64 189 189 97 (-100)
2017-04-27 15:51:46,293 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 236 192 14 188 6 145 163 160 5 116 2 4 160 24 253 62 52 144 104 204 (-91)
2017-04-27 15:51:47,416 INFO emoncmsorg sending: https://sample.co.uk/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1493308300.241262,8,1011,0,0,675,4.9,300,300,300,300,300,300,0,-60]]&sentat=1493308307
2017-04-27 15:51:48,249 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 222 20 132 109 12 233 8 21 97 8 121 4 17 7 98 208 38 93 81 175 (-100)
2017-04-27 15:51:48,702 DEBUG emoncmsorg acknowledged receipt with 'ok' from https://sample.co.uk/emoncms
