sroof
(Steve Roof)
3
Excellent tip - thank you!
I found “EditRealTime” in the list of Visualizations in the Setup (I’m running emonPi low-write 10.1.11). I chose my feed that had bad data and zoomed in the time period with bad values. I could not edit single values using the “Edit_feed @ time” option, but after carefully zooming so just the bad data showed in the window, I used the “Multiply data in the wind by …” option and entered NAN then pressed Save. Instantly my bad data was gone! Just be careful - there is no confirmation after pressing Save and apparently no undo.
